![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
High G turn + low fuel = check engine light
I have 25 miles to drive to get to a shop that can check/clear the code that popped up last night while I was driving home. I am looking for some advice on whether or not I should drive it that far (with check engine light on) at freeway speeds all the way.
I was driving home on fumes and a BMW wanted to play and I couldn't refuse. We came up on a hard right hand turn, I was in front, and I dove into the turn in third gear near red line and tapped the brake at the apex of the turn and the check engine light popped on. I know from previous experience that I was pulling at least .9 Gs at that point in the turn. I have 25K miles on my car and this is the first code it has thrown. What do you guys think? |
![]() Drives: 2017 ZL1 Join Date: Mar 2014
I think it is coincidence.
Most Auto parts stores can read the code and tell you what it is. |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
As long as tank is full, I think you're fine driving it to mechanic. But you need an OBD 2 scanner, they're like $30-$60. I like the Autel ones and prefer a cable to a Bluetooth link, Amazon has them and I'm sure Autozone has a good selection.
I think with high G and no fuel you probably had a brief fuel starvation and maybe knock from lean out, or maybe just code for low fuel pressure, etc. Probably once is not an issue and the ECU safety measures protected the motor, but don't ever do that again :-) If you have a warranty and go to dealer, don't tell them this story. Just say you were cruising on freeway and light came on. |
![]() Drives: Buick Grand National, BMW M5 Join Date: Nov 2019
You didn’t finish your story.
At the turn was the BMW in your rear view or your PDR ? |
#5 | |
#6 | |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
You will be fine. This is a fairly common issue with low fuel levels and high g right turns. The pump is on the left side of the tank and can be momentarily starved for fuel under these conditions. There's nothing wrong with your car. Get a cheap obd2 Bluetooth adapter and download the Torque app to read/clear the codes, which in your case will be 0231- low secondar fuel system voltage, and 069 - fuel pump control module requested MIL.
Baby Blue
#8 |
![]() Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
Pretty common problem at AutoX events with any car. This happened with my GT3. Got into a limp home mode with errors. A little gas fixed the issues. Not great to be killing it on fumes.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
#9 | |
![]() Drives: 2019 ZL1 1LE Join Date: Dec 2019
If the pump is on the left side, a high G right turn would not uncover the pickup, but a high G left turn sure could.... same issue can exist in wet sump oil systems under high lateral G and heavy braking... hopefully Chevy spent a lot of time on oil pan design, pickup location and baffling... One of the many advantages of a dry sump ... |
#10 | |
It will be interesting to see what CELs the pop's car threw. I haven't heard of any low side CELs on a bone stock car.
Baby Blue
#11 |
I was really off my game on this one...pump is on the other left, ie the right...
Baby Blue
#12 |
#13 |
