Old 09-17-2020, 07:27 AM   #1
Fraxum
Fraxum's Avatar
Velossa Tech Scoop on an LT1
Has anyone with an LT1 model tried to fit the Velossa Tech Scoop?
I have one coming and will try first the radiator cover method rather than taking the bumper cover off. Although then I could look for a way to mount a tow hook. No Ram Air but hopefully lower IATs. They did give me a $30 discount to try an LT1 fitment, but it will not affect my review. I have no way to measure that, but wait maybe I do. I have a newer HPTuners brick. I guess I can record runs even though I do not have the tune open. But then I can't use my shift light.
I am also adding an LT2 IM to continue my M6 11 second quest with the seats in and no tune.
Old 09-17-2020, 07:44 AM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
going in through the radiator cover is much easier than removing the bumper cover. the hardest part is trying the get the radiator cover to slide out and back in without scratching anything. Just take your time and be careful.
Jaxcam02 is offline   Reply With Quote
Old 09-17-2020, 08:25 AM   #3
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
https://youtu.be/spc6wWoHqE8
Jorge put one on his car, here’s a video of it on his channel.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-18-2020, 01:07 PM   #4
OneSlowV
OneSlowV's Avatar
Drives: 2018 camaro ss
It doesn’t fit like it should which you will see when you go to install .
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved
OneSlowV is offline   Reply With Quote
Old 09-18-2020, 10:56 PM   #5
Fraxum
Fraxum's Avatar
You have my attention. Any advice?
My LT1 is crushing my 2016 M6 SS times but with a little help...... 119 mph?
You also have a fast Dodge. Jealous.
Old 09-18-2020, 11:05 PM   #6
Fraxum
Fraxum's Avatar
Thanks!
Old 09-19-2020, 12:23 AM   #7
s346k
s346k's Avatar
Drives: like an old lady
youd pick up an easy 1+ mph by putting 26" tires on that thing. those 28s are killing you.
Old 09-19-2020, 03:34 AM   #8
OneSlowV
OneSlowV's Avatar
I just put it in as best as I could i removed hood latch and metal trim and went in that away . And thank you
Old 09-19-2020, 01:35 PM   #9
appleman22
Drives: 2017 1ss 1le
lt2 intake manifold needs a tune. Especially if you are running high rpms. do the research they lean out up top using a stock tune.
appleman22 is offline   Reply With Quote
Old 09-25-2020, 07:17 AM   #10
Fraxum
Fraxum's Avatar
I saw! I went with the radiator cover mehod. What a PIA. But better than taking the bumper cover off. I just jammed mine in there, But I did not see anything to bolt it on to and saw 2 pieces of plastic to take off. The crossbar there sort of holds it in. I had to unbolt the latch mechanism. Now I wish I would have taken off the Rotofab to see the path there. It is also facing slightly down.
Old 09-25-2020, 10:42 AM   #11
WhitesnakeSS
WhitesnakeSS's Avatar
Drives: 2018 Camaro SS
Mine fit fine. I took off the radiator cover and hood latch and with a few minutes of wiggling it around it finally fell into place. No alignment issues at all.
WhitesnakeSS is offline   Reply With Quote
Old 09-25-2020, 12:06 PM   #12
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
take the bumper cover off, it easy and you can make sure everthing is instaled correctly.
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 09-25-2020, 02:28 PM   #13
Fraxum
Fraxum's Avatar
Now you have me worried. I do that often.....
Old 09-25-2020, 02:33 PM   #14
Fraxum
Fraxum's Avatar
LT1s are a different fit, but agreed if I take the bumper cover off I might be able to mod it to fit, a winter project.
