Old 09-14-2020, 08:19 PM   #1
Kilo_SME
Drives: 2016 Camaro 2ss
JLT intake tune
Hi, I was wondering if anyone could point me in the right direction to getting the JLT intake running. If any had a HP tuners file they wouldn't mind sharing that would be great!!!
Kilo_SME is offline   Reply With Quote
Old 09-18-2020, 11:41 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The only thing I can offer is when I went from a standard sized CAI(4.5" Rotofab) to the 5" big gulp I had to add 25% more airflow to the maf in the closed loop fueling areas(1300-7200hz). Then in the areas where you transition to Open loop PE(7450-10000hz)required 10-15%. Take note these MAF values I used are just a generalization.
You could likely multiply the entire MAF table by 1.20, then go back and log MAF vs LTFT error for closed loop(idle & part throttle) and MAF vs wideband(EQ error) for PE fueling(WOT) and tweak it in from there.
