Old 09-14-2020, 02:00 PM   #1
OutlawV2
Drives: 2018 ZL1 1LE
ZL1 burning oil at an accelerated rate
Ok so I have a 2018 ZL1 1LE. Currently has 21K miles. I purchased the car with 9k miles back in November of 2019.
When I left dealership car was fully serviced. Oil change light came on at 15,000 est miles.
I had oil changed at a reputable shop near me that always does oil changes when I don't feel like laying under it myself or going on base to the hobby shop and their lifts.....
Guy tells me "Hey it's gonna be a little extra cause that thing takes TEN quarts..."
After the surprise of hearing TEN quarts, I was like 'yeah man whatever it takes bro..."
And he says "Hey btw, your car was two quarts low when you brought it in. It wasn't even reading on the dip stick."
So now my ears perked up. Cause no way in hell does a new car with no leaks burn two quarts of oil in like 6k miles..... So at first I think maybe the old dealership didn't know what the **** they were doing and underserviced it..... Unlikely but possible..
Fast forward to like four days ago.... Car now has 21K On it..... Oil percentage left from the oil change at 15K is like 33% left.... So I figured a perfect time to check the level.....
Nothing on the dipstick......
So I had to purchase two more quarts of MOBIL 1 syn and service myself right there..... sure enough after two quarts it was high up on the stick but in the operating range...
So here's my question for the masses.....
Bring it to the dealership and Immediately do what???? Order a compression test or an engine diagnostic????
Cause oil burning at this rate is motor death as far as i understand... And I want to know early if I'm going to need to get a free LT4...... thought's opinions???
2018 ZL1 1LE Summit White M6
"MOVN WA8" currently stock
2012 CTS-V Diamond White A6 Coupe "Becky"
1995 Z28 1LE 383" LT1 A3 N2O Drag Car 9.06@153
OutlawV2 is offline   Reply With Quote
Old 09-14-2020, 02:20 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
If your ZLE is not modded then you still have warranty left. Next oil change or if needed now take it to a Chevy dealer and let them do the oil change and mention that the engine is using so many quarts between change intervals so the complaint can be documented by a service advisor. My ZL1 was about a quart low a couple of weeks ago and doesn’t seem to be using any now. Mine has about 15,000 miles now and I’m constantly checking the level every week before driving 2 to 3 days of each week depending on weather conditions of course. Hope I have given you some info to help you.
Old 09-14-2020, 02:23 PM   #3
LT4Greg
LT4Greg's Avatar
And yes our LT4 engines take 10 quarts to fill as does the LT1 engine.
Old 09-14-2020, 02:23 PM   #4
OutlawV2
The only thing I hate about that is paying the service department some ridiculous amount of money to change my oil when Johnny next door can do it for way less.
But I feel what you're saying ........ yeah cuz something dont' sit right with me about a car using a couple of QUARTS of oil between changes.... and lots of people on this forum have ZERO consumption issues.....
Old 09-14-2020, 02:30 PM   #5
LT4Greg
LT4Greg's Avatar
Yeah I do understand what you are thinking but the oil usage needs to be documented by GM just in case you do have a bad engine. It will hopefully be easier if it’s checked and documented by GM for a engine replacement under your drivetrain warranty.��
Old 09-14-2020, 03:12 PM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
See if your dealer will let you provide your own oil and filter and just charge you labor for changing it. My dealer when i lived in NY would do that. Labor was usually $20-25. I'll find out soon if I can do that here in NC.
Old 09-14-2020, 04:44 PM   #7
OutlawV2
Yeah all good... I'm gonna bring it to the dealer with my findings so far and see if they'll work me something where they can document it...
JB
Old 09-14-2020, 05:14 PM   #8
beemer105
Drives: Chevrolet Camaro ZL1 1LE
at what usage level would you think is too much?
1 quart within say 5000miles?
2 quarts?
For instance what about 1 quart of usage within 1500miles but over an 8 month interval?
beemer105 is offline   Reply With Quote
Old 09-14-2020, 06:06 PM   #9
LT4Greg
LT4Greg's Avatar
Let us know what the dealer tells you JB!��
Old 09-14-2020, 06:12 PM   #10
LT4Greg
LT4Greg's Avatar
2 quarts?
I would think that a quart used in 5000 miles is not too bad but some folks would on this forum. Usage depends on your driving habits and how well you take care of your car.
Old 09-14-2020, 06:19 PM   #11
LT4Greg
LT4Greg's Avatar
The dealership here where I live will let you bring your own oil but they have to supply the oil filter. My question and concern would be if they used your oil to do the service or the oil they have in stock. I like and use Valvoline synthetic 5w30 in mine and I wouldn’t know if they put it in my ZL1 or Mobil 1 what they use.
Old 09-14-2020, 06:28 PM   #12
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
You just need to check your oil more often. The dealer will likely do nothing, if it's only a quart every 3000 miles....
Rayvan is offline   Reply With Quote
Old 09-14-2020, 07:28 PM   #13
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
I'm having a similar problem with only 10k miles. Although its been about 2 quarts in maybe 1500-2000 miles. I've been advised by a gm parts manager to tell them about it like stated before and ask for an oil consumption test. That's pretty much where I'm at. Good luck
Old 09-14-2020, 09:26 PM   #14
collinms
Drives: 2017 ZL1 A10 Summit White
Mine drinks about 2 quarts between changes.
collinms is offline   Reply With Quote
