![]() Drives: 2018 ZLE Join Date: Mar 2020
Before and after flex fuel tune *Dragy results
Just wanted to share some quick Dragy comparison data on my 18’ 6M/T ZLE. This is before and after adding a flex fuel sensor and a flex fuel tune.
(Stock boost no pulley swap on both runs shown below) First run rotofab intake standard, and cat back exhaust stock tuning 93octane Second run Rotofab intake standard, cat back exhaust and flex fuel sensor with flex tuning from BRC E50 fuel. https://brcraceworks.com/ Cliff notes: Car is full weight, both runs I had a full tank to keep things as similar as possible. Temps were 10* cooler on the second run. I think it will go even quicker once I have a few more tries as Traction is now an issue from 50-60mph so there was some spinning through second gear when I hit it. Overall I’m blown away by how much quicker the car is without increasing boost, just a flex fuel sensor and calibration for pump up to e60. |
![]() Drives: 18 ZL1 Convertible Join Date: Jun 2019
Those are pretty stout results. I’m thinking about doing a flex fuel sensor also. Did u install yourself? Was it difficult?
I’ve never done anything like that before so I’m not sure how challenging it would be. |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
60 horses off just a flex fuel tune? That's a good bargain.
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
That’s a sweet torque gain.
Ghost Spawn
Drives: Camaro Join Date: Jan 2019
Awesome results
It was pretty easy, I think it took an hour in total. I followed a YouTube vid and got it done without any issues. Main thing is when you pin it into the plug triple check you are inserting the wire into the correct pin. I went with the advanced fuel dynamics kit that has a Bluetooth module so you can connect with your phone through their app and see live ethanol content.
#7 |
Yeah it was actually more then that, the car baselined at 590 before any tuning was done. I’m blown away by how much better it drives too, taking off from a light there was always a dead spot in the pedal which made it want to choke up a little and that is also completely gone.
#8 | |
#9 |
![]() Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
+60 hp is also about what I picked up when I switched to E85.
#10 |
![]() Drives: 4 wheels and a motor Join Date: Feb 2017
First name Shea?
Just curious... not many of us.
#11 |
#12 | |
![]() Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
#13 |
Did u have it remote tuned? U don’t have any headers? Car is just intake and E50?
#14 | |
