Old 09-13-2020, 08:06 PM   #1
supersportss
Drives: 2019 SS
LT1 on spray
The LT1 loves spray, we ran some good numbers keep the blowers and turbos, Im sprayin.
supersportss is offline   Reply With Quote
Old 09-13-2020, 08:24 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Thanks for that Snippet of info.
Old 09-13-2020, 08:42 PM   #3
supersportss
Drives: 2019 SS
You're welcome.
Old 09-13-2020, 10:29 PM   #4
laynlo15
Drives: 2022 Lt1 A10
I like the spray but don't know much about it so give us some other details. Thats probably a mid 10 second pass in the 1/4. Congrats.
Old 09-14-2020, 12:29 PM   #5
supersportss
Drives: 2019 SS
Nitrous Outlet 90 MM GM wet plate system, 400 shot capable some wiring and tuning needed. I'm running a 300 shot with a progressive controller, with 315 Nitto NTo5 drag radials.
Old 09-14-2020, 01:38 PM   #6
KingLT1
KingLT1's Avatar
I would suggest considering direct port for a shot that large.
Old 09-14-2020, 11:55 PM   #7
gtfoxy
Drives: '21 Wild Cherry ZL1
Juice is great.
Until the bottle runs out that is.
Haven’t hit the sauce since 99. Boost is the cure for empty bottle blues.
Old 09-15-2020, 06:55 AM   #8
turboalb
Drives: 2016 camaro ss
What are your mods, nice time , that's probably a 10.25 133 mph
turboalb is offline   Reply With Quote
Old 09-15-2020, 08:45 AM   #9
Umbriel
Drives: 2016 Camaro SS
Having to keep bottle pressure up, having to constantly refill bottles which isn't cheap, having a solenoid fail and destroy a motor, worrying about nitrous backfires etc... I used to use nitrous but once I turboed one of my Camaros I never went back, power is always there and you don't have to worry about all of that other crap. Plus the feeling of having boost kick in is very addictive.
Umbriel is offline   Reply With Quote
Old 09-15-2020, 09:12 AM   #10
CaliforniaKid
Drives: 2018 ZLE
That’s a big shot through the TB plate! I’ll bet if you check your plugs after a few bottles they don’t all look the same be careful!
CaliforniaKid is offline   Reply With Quote
Old 09-15-2020, 09:21 AM   #11
LT1ornothing
Drives: 2020 LT1 M6
Congrats! It is most definitely the most economical power adder by a long shot. I still got my bottle from my 4th gen ls1 that must have seen over 100 refills. The costs starts adding up over time with the refills though. I've had a fuel solenoid stick in the past and blew up an intake manifold, I've had a nitrous backfire cause a spun rod bearing. All I can say is be careful and be safe, test your solenoids often. I don't think I will ever spray a large shot again though, this time around it's definitely going to get boosted.
