Old 09-12-2020, 02:45 PM   #1
Walnutbear
Walnutbear's Avatar
Drives: 2019 Zl1
BC FORGED wheels, tires
New wheels and tires from Pkautodesign
BC Forged 2 piece
305/30/19 Fronts
325/30/19 Rears
ZLE specs
5mm front spacers
3mm rear spacers
Not sure about the spacers yet.
Walnutbear is offline   Reply With Quote
Old 09-12-2020, 02:51 PM   #2
impulse
impulse's Avatar
Drives: Big Dually ... RIP ZL1
The blue cyclone special
Imagine impulsively buying a Summit ZL1.
impulse is offline   Reply With Quote
Old 09-12-2020, 02:55 PM   #3
suzbndt
suzbndt's Avatar
Drives: 2010 Camaro SS 2011 Mustang GT
For sale?
Sent from my SM-N960U using Tapatalk
suzbndt is offline   Reply With Quote
Old 09-12-2020, 03:02 PM   #4
Markoz28
Drives: 18 ZL1 nightfall grey A10
If you don’t need the spacers, I would take them off. Unless you didn’t factor in the correct offset for the wheels?
BC makes amazing wheels. Those are a bit busy but if you dig them that’s awesome!
Markoz28 is offline   Reply With Quote
Old 09-12-2020, 03:22 PM   #5
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
These are fully modular, so they shouldn't need spacers... I am wondering if these were for a different application and just happened to fit the ZL1. They do make beautiful wheels though.
SS 376 is offline   Reply With Quote
Old 09-12-2020, 03:31 PM   #6
suzbndt
suzbndt's Avatar
I love my bc wheels. No spacers
Old 09-12-2020, 03:46 PM   #7
Markoz28
BC Forged are top quality for sure
Old 09-12-2020, 04:50 PM   #8
Walnutbear
Walnutbear's Avatar
Drives: 2019 Zl1
The only reason I used spacers is because of reading about rubbing in the front and rear wiring . These where made for my zl1. I will try removing them.
Old 09-12-2020, 05:37 PM   #9
Markoz28
The wire harness on the ZL1 is the same as the one on the ZLE so there is no difference there. There is a difference in the front suspension so a small spacer might be needed. I would remove the rear spacer and put that one in the front so it’s not too pushed out but enough to clear suspension if needed.
Old 09-12-2020, 07:38 PM   #10
Cleancoupe
Drives: 18 ZL1 1LE
If you’re buying custom wheels why wouldn’t you just buy the offsets you need for your car?
Cleancoupe is offline   Reply With Quote
Old 09-12-2020, 07:56 PM   #11
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Those look fun to clean.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 09-12-2020, 09:45 PM   #12
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
BC Forged 2 piece
305/30/19 Fronts
325/30/19 Rears
ZLE specs
5mm front spacers
3mm rear spacers
Too much poke, IMHO. I’d get rid of the spacers.
CW3SF is offline   Reply With Quote
Old 09-12-2020, 11:34 PM   #13
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
What model are your BCs and any more pics?
SienarSystems is offline   Reply With Quote
Old 09-13-2020, 05:41 AM   #14
suzbndt
suzbndt's Avatar
Rz23 brushed bronze finish. There are bunches of pics on my Instagram page @suzbndt mine have 5mm more offset up front for clearance because I leave the track alignment setting
