![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
GM LT1 Hot Kit?
Looking for further information on GM's LT1 Hot Head and Cam kit (PN: 19333525)
What does it come with? Anyone have results? Results with a supercharger? The basics are Hot cam (19303897), 8 lifters, 4 lifter trays, and two CNC'ed cylinder heads (19329839) complete with spring/valves, etc. Summit has the kit at $3102.62. If you price the heads (2*$948) and cam ($575) separately it is quite a bit cheaper. The lifters/trays can't be the only included part... I will be doing a head upgrade this winter, but not sold on a cam (but do like GM products!). I do desire more top end power, but have limitations on how to do it with German challenges. GM initially offered it as part of a LT1 crate engine (535 HP/PN: 19355378), but appears to be discontinued: https://www.hotrod.com/articles/new-...cam-tensema16/ https://www.chevrolet.com/performanc...s/lt/lt376-535 Thanks.
Moderator
I would imagine a cam designed for an N/A car would have more overlap than you’d want for a boosted car. Give CamMotion a call and get a cam custom ground for what you want to do with the car IMO.
![]() Drives: 21 SS Join Date: Oct 2017
I haven't gotten installed yet but I bought the lt1 cam separately and cam motion dod delete kit. I'm probably skipping heads.
FBO, E85
11.1@123 |
Josh: Appreciate the comments. Agree a custom cam is the right answer. I used to believe a NA cam is different than a non-NA cam, but some reputable sources say that isn't always the case...at least it isn't as bad as some believe if you have a cam already. The power curve is just more so with an adder. I'm no expert though.
I also wonder if the specs Chevy publishes for the HOT cam - if they are equivalent to what the aftermarket cams are measured at. Chevy advertised 80 HP increase with the CNC heads and cam package according to their Crate Engine info. 7speed: Appreciate chiming in! I'm only aware of 2 others on this forum who used the package/cam. One sold the car (commented he had couple of lifter failures) and the other silent. Please report back on your experiences...also highly recommend dynoing the car prior ideally on the same dyno for actual improvement. I've done this many times and gives great justification for your money spent.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
535/470? is that crank hp? if you are wanting to add power and cash the warranty, i'd suggest doing bolt ons if that's all the more you want. full bolt ons will gain you close to 100 whp while retaining stock drivability and stock internal parts.
if you want boost on top of that you mise well build a short block for it. 6 lb on a bolt on motor will easily push it over the reliable limit of the stock pistons.
s346k: Appreciate the post...I'd like to keep the discussion on experiences with the GM Hot Kit - thanks.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
My take away. I did mine at a GM Performance dealership and it was their first GEN V cam swap. My advice make sure they have done them before. I would only do cam and not included heads if i did it again. Just lifters, springs, and rocker kit. The GM Hot cam sounds bad ass but lacks in punch. The Torque pick up was about 50 to the wheels, other cams could do better. It was a pig on gas but that sound was worth it. The tuner was the most important.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#8 |
BlackbeastSS2: I believe you were one of the two that I'd seen post about an experience. You talk in past tense - do you no longer have the package? Did you do before/after dyno tests? How do you know if the cam or heads were to blame for the lower than expected performance? And you mention springs - Hot cam is compatible with the original springs - did you install others? Thanks.
#9 |
I don't believe the Hot cam has a larger fuel lobe to overdrive the HPFP. That is the biggest reason why I wouldn't run it in a Supercharged application. Note the OP has a LT4 supercharger on his LT1.
#10 | |
I am just a self taught garage monkey from the 70’s and like to fiddle with my cars. Anything above stock is good for me. Not gunning for the best and fastest but I do enjoy what I am doing in my own garage. Currently doing my current car build and learnt that taking your time is better and getting all the parts before I go to the tuner. Edit. Forgot to mention the reason to upgrade heads because you should do all the lifters anyways. So your in there anyways, so upgrade. Plus if your an Auto your going to have to do the DOD delete anyways.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 09-13-2020 at 12:30 PM. |
#11 |
KingLT1: Did not know that, although I don't think I'm looking to make that much more HP. I've got my hands full on the circuit as it is...just need a bit more on the autobahn!
BlackbeastSS2: I understand. To confirm, the kit only came with heads/cam, lifters, and tray...nothing else? Seems odd the package deal is more than the pieces separately. I'm inquiring about the head upgrade for the same reason as you...lifter replacement primarily. I will also be performing all the work (with possibly a young assistant or two). Thanks.
#12 | |
This Kit Includes: 19303897 (1) Camshaft 12595365 (4) Valve Lifter Guide 12648846 (8) Valve Lifters 19329839 (2) CNC Cylinder Head Assembly I am just say you might just want to get just the cam and reinforce your stock heads since you have to do a DOD delete. That’s the way I would go after doing the full complete heads. IMO
#13 | |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I've been reading a lot of good things about Cammotion. I've run hotcams in my previous Camaros and really liked them. They were easy on valvesprings and ran as good at the track as a lot of "custom" cammed guys. Had one in my 95 Z28 and my 99 Z28 (first one). I've watched videos of Westtech Performance and Richard Holdener showing many "n/a" cams doing just fine with a supercharger. I can't imagine this engine is that different, but I don't know if he did any direct injected engines to illustrate this point.
I too have been eyeing this hotcam package, but am pretty sure a cam motion 600 ish lift cam. .625" valve springs, Johnson lifters, and ported heads from Pray or another reputable porter is the way to go. I daily drive mine and don't want to lose much bottom end, but still make a big difference up top.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#14 | |
Imo the Hot cam is the wrong package for your setup. My recommendation would be to get something from cam motion.
