![]() Drives: 2019 Zl1 Join Date: Aug 2016
Front shock spring spacer?
Hi all.
I want to say I've found the problem with a bumping noise in the driver side front of my car. This was on the shock spring. The noise is gone now. The other side had nothing on it. I found this while installing my new wheels. I was waiting to take it to the shop after I installed the wheels. Driven about 3000 miles with this on.
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Hey, they not only left it in, but wasn't it upside down? Looks like UP arrow is facing down......
Yes it was upside down.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
So much for Dealer prep!! One day i was at the dealer for another reason and noticed the car on the showroom still hand them on and i went up to the manager and told them. They had no clue.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
This can cause damage to the mangneto ride and I would have left it on, called the dealer and had them tow it back to remove it. Then have it stated in the maintenance logs that they left it on so in the future if you had issues with the mangneto ride then they would be responsible.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
It's probably going to ride a little better now :P
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
#7 |
![]() Drives: '17 ZL1 A10 Vert Join Date: Mar 2017
My dealer forgot to take them out as well, although it didn’t cause any noises. I discovered it when I got home. The only problem was the drive from the dealer to my house was over 500 miles...
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
They were removed when I bought my used 2017 ZL1 but I did find one under the passenger seat before leaving the dealership lot. I showed it to the salesman and asked him what it was and of course he didn’t know. I later found out what they were in the owners manual supplement and decided I would order one to have a pair to use if the Z ever needs to be put on a rollback.
#9 |
![]() Drives: Current driver AMC emlin X 5ltr. Join Date: May 2011
Do the 1LE'S have these spacers?
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
These are spring spacers that are designed to be used on the front springs to increase the road clearance if/when the car needs to be loaded on a flat bed car carrier.
The dealer is supposed to remove them when delivered as part of the prep and then put them in your glove compartment for you in case you need to use them at a later point. |
#11 |
Thank you everyone.
#12 |
#13 |
![]() Drives: 14 Silvy 1500 Z71; 20 Camaro ZLE M6 Join Date: Jun 2017
ZL1 1LE does not come with spacers
#14 |
![]() Drives: 2024 Camaro ZL1 Join Date: Aug 2023
I drove my new 2024 ZL1 home yesterday all smooth highway driving. I got home, my driveway is gravel 800' long and uneven in places and I can only drive 5mph on it. This morning when leaving for work a found both of the spring spacers in the driveway, about 200' apart.
