Old 09-10-2020, 06:39 PM   #1
pizokk1
pizokk1's Avatar
Drives: -17 hyper blue 1ss black rims
Bigger tire on 20x11 and 20x10??
Have any of you guys have try to squish in the next size of tire on regular zl1 and ss1le wheel size? I have HRE’s wheels with the same tire set up as ss 1le and zl1 and im trying to upgrade to mps4s to 315 30 20 to 11 wheel and 295 30 20 to 10 wheel, but i have not seen how the profile of the tire is going to look on the whee. If any of you have this same tire size can you post pictures to get a idea on how it is going to look? Thanks in advance guys!
pizokk1 is offline   Reply With Quote
Old 09-10-2020, 07:12 PM   #2
I can show you what 315/30/20 PS4S on a 11" wheel (offset +43) with a 5mm spacer looks like in the rear, see below.
Up front I run 275/35/20 for more sidewall, and because my car is also a standard SS and I didn't want to distort the ratios too much, lest stabilitrak or the ABS start to complain.
Old 09-10-2020, 07:32 PM   #3
pizokk1
pizokk1's Avatar
It looks so good, mine is also standar ss thats whay i was trying to see if i could go that way but i guess not right now in front i have 285 30 on 10 wheel
Old 09-10-2020, 08:18 PM   #4
06 4.8
Drives: 2016 2ss, E85, tune, intake
Probably can’t see my sig pic too good but if you want to creep on my IG you can see good pics of my car on there with the velgens x10s and x11s and I run ZL1 285/30 and 305/30 in my SS.
Chadh076_0
2016 2SS, A8, cat delete, DSX E85 kit, CAI, tuned, Velgens.
1949 F-1. Camaro frame on full coil overs, CCWs, cammed LS, built 80, yada yada
06 4.8 is offline   Reply With Quote
Old 09-10-2020, 08:22 PM   #5
pizokk1
pizokk1's Avatar
Ok thanks ill hit you up bro
Chadh076_0
Old 09-10-2020, 10:48 PM   #6
Markoz28
Drives: 18 ZL1 nightfall grey A10
I run 295/30/20 on 20x10 and 325/30/20 on 20x11.5” wheel
Markoz28 is offline   Reply With Quote
Old 09-11-2020, 12:13 AM   #7
Cwells22
Good to know. I want the Ferrada 10.5 in front and 11.5 in back and they keep saying too aggressive.
Cwells22 is offline   Reply With Quote
Old 09-11-2020, 01:13 AM   #8
pizokk1
pizokk1's Avatar
Can you show pictures? Do you need spacers? Does it rub?
Old 09-11-2020, 09:22 AM   #9
Mohawk_1SS
Drives: 2019 Camaro 1SS M6
I've been running 275/35/20s on the fronts and 315/30/20s on the rear. I'm not running any spacers. Pics of how they look on the car below.
Mohawk_1SS is offline   Reply With Quote
Old 09-13-2020, 02:32 PM   #10
Markoz28
No spacers bc they have a custom offset
Old 07-01-2021, 02:33 PM   #11
jamessh10
jamessh10's Avatar
Drives: 2018 camaro 2SS
why do you run the spacer? I see many people running it without the spacer with just moving the harness.. i have a ss as well and i plan on using you're same setup minus the spacers.
jamessh10 is offline   Reply With Quote
Old 07-01-2021, 06:52 PM   #12
That's a good question, I meant to use them for 100% safety against rubbing, but clearly there is enough room after relocating the harness. I might as well remove them.
Old 07-08-2021, 09:36 AM   #13
jamessh10
jamessh10's Avatar
I would, to move the harness takes 30 mins. mainly bc of all the tabs to take out.
what offset is your fronts?
i just bought 10" fronts (+23) and 11" rear (+43)
do you have mag ride?
Im hoping 275/35/20 doesnt hit my strut
Old 07-08-2021, 02:43 PM   #14
Skyman2112
Skyman2112's Avatar
Drives: 2016 2SS blue velvet w/blk stripes
Question
im gonna copy your setup!!! Are those PS4S tires better than the stock ones for occasional strip use? They dont make a drag radial in the 315 size i want. Thanks for any advice!!
Skyman2112 is offline   Reply With Quote
