Old 09-08-2020, 02:06 PM   #1
delthawk5
Drives: 2019 2SS Crush
Winter Driving, The Rockies, etc, etc
I'm likely re-locating from Florida to Denver for work in November. Yeah, I'm gonna be THAT guy who can't drive in the snow. Already have my 2019 2SS on Michelin AS3+ which are decently rated for winter, do I need to have any other concerns about winter driving my SS besides slapping that mode button to snow?
Might consider buying a beater car like a 4Runner...won't be commuting thanks to COVID this year, but the year after might be a different story.
delthawk5 is offline   Reply With Quote
Old 09-08-2020, 02:16 PM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Really just depends on how harsh the winter is, but I have a dedicated snow tires and wheels setup. Mild winter no problem, anything more than that you might regret not going to a dedicated snow tire
HCI2000SS is offline   Reply With Quote
Old 09-08-2020, 02:25 PM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
As someone who has lived in Colorado and had muscle cars, get a beater to drive around in winter. I moved from the northeast to Colorado and my insurance went up....was told it's because there are soo many accidents. Because the air is soo dry even a light dusting turns into a nightmare as the dusting turns into black ice the moment someone drives thru the dusting. I've never seen soo many people slide into the middle of intersections (stop signs or red lights) because they couldn't stop and either slid into the person in front of them or get hit (T-bone) by someone coming from the other direction.
nancygrl is offline   Reply With Quote
Old 09-08-2020, 02:35 PM   #4
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I work from home as well, so I don't HAVE to drive. I run Michelin Pilot Alpin N-Spec (Porsche spec) tires, 265/19 square setup w/ front spacers and it does ok around the front range, but if you're going anywhere the roads have a steeper grade it might get sketchy. Specifically, trying to get going up a steeper hill in the snow may be impossible, so if you're going to drive in the mountains anytime there may be snow you may need a tire chain-like device in the car for an emergency situation. In some spots like I-70, not having a chain-like device or specific winter tires is illegal.
If you need to be able to drive anytime or drive in the mountains during the snow season then a 2nd car is definitely a good idea.
Old 09-08-2020, 02:42 PM   #5
delthawk5
According to the GEICO quote machine, moving from Florida to Colorado will drop my insurance by $850/yr...Florida drivers are god awful.
Old 09-08-2020, 02:44 PM   #6
nancygrl
雪の玉
nancygrl's Avatar
I know FL drivers are pretty bad, seen plenty example when driving up/down the east coast on I-95....Wow... So that's good $850 cheaper, but I'd still get a beater for moving to Colorado
Old 09-08-2020, 03:05 PM   #7
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
The worst part of driving in snow here is that they use huge amounts of salt on the roads.
7LitreC5 is offline   Reply With Quote
Old 09-08-2020, 03:56 PM   #8
Rhobz
Rhobz's Avatar
I am relocating from San Diego to Colorado Springs in 3 weeks for work so don't worry, I will also be THAT guy. My car will be on Michelin PS4s but I do have a second car for the daily duties.
Just wanted to say we are in this together. LOL
Rhobz is offline   Reply With Quote
Old 09-08-2020, 05:47 PM   #9
delthawk5
Are there wash places that will clean the underside of the car?
Old 09-08-2020, 06:15 PM   #10
Aragorn
Drives: Camaro SS 1LE
Are used to roll in and 1987 Mustang GT convertible, in extreme weather. I had studded snow tires in the rear and as long as the terrain was flat, I was actually OK, But as soon as I hit an incline forget about it, I was guaranteed sideways every time. Hopefully that helps.
Aragorn is offline   Reply With Quote
Old 09-08-2020, 06:16 PM   #11
DaveC113
DaveC113's Avatar
They use Mag Chloride which is a PITA but not as bad as places that use NaCl and sand.
Looks like Tire Rack has PA5 and PA4 N-Spec in 265/40/19, I got these on MRR wheels with a 7mm spacer upfront, this corresponds exactly with std 1LE wheel spacing wrt the outside edge so it looks pretty much like stock and keeps the car fun to drive when it's cold out.
I installed 1" longer ARP studs up front and removed the "nose" so it works with both stock and winter wheels w/ 7mm spacers.
These work well and I pass SUVs all the time on roads with packed snow, definitely get some surprised looks, lol...
Old 09-08-2020, 06:43 PM   #12
7LitreC5
Self serves car washes are what I use on my Tahoe in the winter (not the spinning brushes kind).
They use a combination of magnesium chloride sprayed on the roads, brine (sodium chloride in water) also sprayed on the roads, pure dry salt, and a mixture of dry salt/gravel. All very bad
Old 09-08-2020, 06:50 PM   #13
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
Jeez, everybody is moving to Colorado. I'm sorry the border is closed, we're not accepting anymore, we're building a wall... j/k.
Anyway, just get a Subaru and be done with it.
I`m Batman is offline   Reply With Quote
Old 09-08-2020, 07:36 PM   #14
Efi69Cam
Drives: Camaro
50 y/o Colorado native... Camaro for summer, 4wd truck/Jeep for winter. Awd cars are only slightly better than fwd. The highways get cleared but neighborhood streets don’t and you need ground clearance to go over the snow. Happens rarely but getting stuck sucks.
Efi69Cam is offline   Reply With Quote
