Old 09-08-2020, 01:25 PM   #1
ZaraLT168
Drives: Chevrolet Camaro LT1
Rear Brembo on a 2020 LT1???
So I have a 2020 LT1 and it came with front Brembo brakes and standard rear brakes. The SS come with front and rear Brembo. I was wondering if it is possible to simply install SS rear Brembo brakes on an LT1. Has anyone done this?
ZaraLT168 is offline   Reply With Quote
Old 09-08-2020, 01:36 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Nope, not feasible due to park brake differences https://www.camaro6.com/forums/showthread.php?t=480579
Unfortunately there'd be some extra stuff needing done to work around, so it's not a direct-fit solution.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 09-08-2020, 02:13 PM   #3
ZaraLT168
Thank you. There is some good info there.
But the thread you linked is a 2016 1LT (V6 or i4) brake swap with a Brembo SS (v8) setup for the rear. The 2020 LT1 is like 95% SS and share almost every part in the braking system because they are both for the same V8 engine setup. This is why I asked if anyone has tried this for the 2020 Camaro LT1 V8.
Old 09-09-2020, 02:13 PM   #4
ZaraLT168
UPDATE:
I just did a complete parts list breakdown on rear brake system for the 2020 LT1 and it shares the same rear brakes as the 1LT. So the above attached thread holds true for the 2020 LT1 as well.
Old 09-09-2020, 03:13 PM   #5
Wierd Harold
Drives: 2017 2lt rs
Nope. The 1lt does not have parking brake shoes.There is an electric actuator that is part of the caliper,unless you want no parking brake.There are a lot of other mods needed also.
Wierd Harold is offline   Reply With Quote
Old 09-11-2020, 04:32 AM   #6
seethruya
Drives: 2021 Camaro LT1 Conv
Here you go.
https://www.shopchevyparts.com/perfo...-92304340.html
seethruya is offline   Reply With Quote
Old 09-11-2020, 08:24 AM   #7
Alpha1BC
Alpha1BC's Avatar
Originally Posted by seethruya View Post
The website is inaccurate. This kit will not work with the LT1 trim Camaros, only the 1SS or 2SS trims due to the park brake differences outlined in the above post and linked thread.
2017 SS 1LE.
Old 09-11-2020, 09:24 AM   #8
stlwrx
Drives: 2020 LT1, 04 JDM STI, 18 BMW
Saves you money from having to to a conversion on the rear for 15 in raidals..score!
stlwrx is offline   Reply With Quote
Old 09-11-2020, 09:57 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Unfortunately you have to change the spindles for the 15" conversion on a LT1.
Old 09-11-2020, 10:13 AM   #10
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Should have picked up a 1SS or order it with the LT1. But then ordering extras on a LT1 defeats the purpose of a lower price V8. You don’t get a lot of goodies with the LT1, the square set up and no track mod was enough to scare me away form saving a few thousands of dollars. Don’t get me wrong it’s still got the same power but missing some mods and appearance looks.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-11-2020, 01:35 PM   #11
Awebb
Drives: 2020 Chevy Camaro LT1
Even the official Chevy accessories site lists the rear Brembo upgrade as compatible with the 2020 LT1...?
Awebb is offline   Reply With Quote
Old 09-11-2020, 04:12 PM   #12
Zr8000
Drives: Chevy Camaro
That’s why I ended with a ss. I see no value in the lt1. They are so close in price.
Zr8000 is offline   Reply With Quote
Old 09-11-2020, 05:45 PM   #13
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Someone should buy it and have the dealer install, then ask for the install pdf
I'm sure a bunch of LT guys would be over the moon if this is the case lol
2016 1LT v6
- Totaled
Happiness: Infinite
Old 09-11-2020, 06:06 PM   #14
Fraxum
Fraxum's Avatar
OP why do you want 4 piston Brembos on the back? Rear Brembos are really a track thing to prevent brake fade and go nicely if you upgrade to the six piston Brembos on the front.
I painted my 1lt back brakes red to Match the front brakes. These brakes stop great from 115 mph.
