Old 09-07-2020, 05:01 PM   #1
christisnt
MDRHRNT
Drives: 2019 Camaro SS Fireball Edition
Flashing CEL, No misfires
So I had a flashing CEL (which is commonly associated with a misfire) on my 2019 Camaro SS with D1X Procharger, LT4 High side, LT4 injectors, Fore Innovations dual in tank fuel pump, running e75-e85, which prompted me to get a code reader to see which cylinder it is, so i can pull that spark plug and check it. To my surprise, it showed no misfires. But it showed these codes.
P0121 (This code is thrown every time i let off in the middle of a full pull, goes away within 4-10 ignition cycles)
U0100- I know absolutely nothing about this code or what could cause this code.
christisnt is offline   Reply With Quote
Old 09-08-2020, 08:32 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
A quick Google search seems to indicate that the P0121 is a TPS issue. Could be bad, could be dirty, could be...???
The U0100 is a communication issue where one of the modules couldn't be read. Is it possible that your electrical system / battery isn't up to the task?
Old 09-08-2020, 10:30 AM   #3
ctrlz
Not a bad TPS.
P0121 is a correlation issue, probably with the MAF sensor. Airflow is outside of the expected/allowable range. This will have to be tuned out.
Apparently a common code after installing a supercharger.
I would expect the U0100 to be a bit of a red herring until you deal with the obvious problem.
Old 09-08-2020, 02:19 PM   #4
christisnt
MDRHRNT
Originally Posted by ctrlz View Post
Not a bad TPS.
So basically, you mean that due to the PO121 code, it might be the main cause of the U0100?
Old 09-08-2020, 02:20 PM   #5
christisnt
MDRHRNT
I would like to say my electrical system is definitely capable of handling the task. but i could be wrong for sure
Old 09-08-2020, 02:32 PM   #6
ember1205
Hot Camaro
ember1205's Avatar
I'm not sure if the cars with the LT4 motors get an alternator with higher output or not, that's the only reason I really mentioned the electrical system. Batteries seem somewhat hit or miss in these cars from what I've read. And, since there's a communication issue occurring, that could relate back to electrical.
At a minimum, it sounds like you need to have whoever tuned your car take another look as something seems off.
Old 09-08-2020, 02:59 PM   #7
ctrlz
So basically, you mean that due to the P0121 code, it might be the main cause of the U0100?
U0100 is a very generic code that means some module has lost communication with the ECU. It does not say which module.
Definitely check all connections involved with the supercharger install.
check engine light flashing, misfiring, please help, procharged camaro
