09-06-2020, 10:59 AM | #1 |
Drives: 2017 ZL1 Join Date: Jun 2018
Brake booster failures
This is the second failure Iv had. This booster only lasted 4000 miles. First time it happened at the track. Shut the car off and when I restarted it I had no booster on the brakes. Second time the day after a track day I went out to pick up oil for a oil change and it went out on the way there. I was getting brake assist warnings but they would go Away and function fine. Usually at idol. Has anyone else had this problem? Any ideas on what could be causing it?
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
09-06-2020, 11:13 AM | #2 | |
09-06-2020, 11:14 AM | #3 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Find it hard to believe that the booster is dead on a relatively new car. Probably the check valve or the hose to the booster.
Bryan 2018 ZL1 M6
09-06-2020, 11:59 AM | #4 |
They are coated.
09-11-2020, 08:16 AM | #5 |
They found the cause. A wiring short. Keeps popping the fuse. Can’t find the short yet.
09-11-2020, 08:17 AM | #6 |
Drives: 2018 ZL1 1LE Join Date: May 2019
Hopefully its a simple search! Such an oddball issue to have.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
09-11-2020, 09:02 AM | #7 |
Hope so. Warranty is done. I had the wiring service bulletins done.
09-15-2020, 07:33 PM | #8 |
Update the brake booster gas filled with oil and hydro locked blowing fuses. Now I have to find how and why oil is getting in there.
