Old 09-05-2020, 11:36 PM   #1
asthmamax11
asthmamax11's Avatar
LT1 fuel system guys: how far are you comfortably pushing boost?
Had an awesome time driving in North Georgia mountains today. Car felt amazing with the 888r's on the back.
Thinking of getting smaller pulley for the Magnuson.
Thinking someone needs to talk me out of it.
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-06-2020, 07:01 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
If you’re still on the stock LT1 fuel system, maybe another 30-40 horse safely I’d guess (your sig says you’re at 551 now). Start upgrading that fuel system if you want to play with boost...
Old 09-06-2020, 08:04 AM   #3
laynlo15
Drives: 2022 Lt1 A10
I'd say 600 will be your limit. Are you running the 90mm pulley?
Old 09-06-2020, 01:25 PM   #4
asthmamax11
I'm still on the 98mm...lots of opinions about fuel limits, heat soak, etc have swayed me away from going smaller.
I think people have learned alot more about the platform now than when I got the kit almost 3 years ago
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-06-2020, 02:36 PM   #5
appleman22
Drives: 2017 1ss 1le
i'd more worried about the pistons then the fueling
appleman22 is offline   Reply With Quote
Old 09-06-2020, 04:29 PM   #6
Joshinator99
Moderator
Get the fueling right, and the pistons magically get stronger... I was over 650 wheel last year on stock pistons and rods with no problem.
Old 09-06-2020, 07:03 PM   #7
toohighpsi
Drives: 2015 C7 Z06 M7
Get the fueling right, and the pistons magically get stronger... I was over 650 wheel last year with no problem.
So true - if you get enough fuel and octane, pistons will go pretty far.
We've run at 728 RWHP all summer (10.3s @ 135) with straight E85. We'll be bumping the boost up a bit more for our next track outing to drop into the single digits. Will that be the limit? Maybe - we'll let you know.
Old 09-06-2020, 10:19 PM   #8
asthmamax11
Ok thanks alot guys
Good to hear other's experiences
My car still puts a smile in my face everytime I drive it. Can't imagine not having boost now. Lol
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-07-2020, 08:53 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would leave the boost alone, upgrade the fuel system, flex sensor, and run a mix of E for added octane and cooling. You will make more "safe" power then upping the boost with the stock fuel system on 93. I bet you would hit around 600whp with E60. 93 pump isn't really enough octane for these high compression engines unless we are talking very low boost levels(5-7psi tops) which is why many are pinching the rings. Yes they have tight ring gaps but if the compression was a point lower like the LT4 they would tolerate a lot more power on 93 and likely be less failures.
Old 09-07-2020, 06:32 PM   #10
PeteSS2018
Drives: 2018 2SS Camaro
I'm at 9.5psi, apparently a relatively conservative tune, about 560whp. In a year of driving Ive had no issues, although I dont drive it hard too often either and rarely get anywhere near redline ....
PeteSS2018 is offline   Reply With Quote
Old 09-07-2020, 08:54 PM   #11
asthmamax11
Upgrading fuel system is a big commitment.
I would upgrade the Cam also.
It just seems when you get close to 600whp it is exponentially more expensive to push past it than to just let it be at a "safe" level based on what kind of octane is available.
Aftermarket is still atrociously expensive for alot of parts on 6th gens
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-08-2020, 09:01 AM   #12
laynlo15
I think the fuel system is a good route. Probably around 2000.00 with labor. Its a pretty easy job on a 2300 Maggie. Injectors are not plentiful at this time and hard to get unless something has changed in the last week or so.
Old 09-08-2020, 09:30 AM   #13
KingLT1
KingLT1's Avatar
I agree 2000.00 for another 100whp + of fuel system headroom isn't really that bad. Honestly if I was starting over I would of bought the +30 FIC injectors instead of the LT4 because I could probably run Full pump E at this boost and some. Especially since they have came down in price. The FIC literally take 5 minutes to tune.
I think the best approach is to invest in the fuel system first, then build the motor second depending on goals. These engines will tolerate some pretty good power if you keep the cylinders cool.
Old 09-08-2020, 08:33 PM   #14
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
And for 93 Octane pure pump (no added Meth), between the 550 - 600 RWHP even at the stock LT4 Charger Pulley size - producing ~ 9- 9.5 PSI:
Would the upgrade to the LT4 fueling safeguard the pistons from heating too much (and then potentially causing the rings to butt)?
