Old 09-05-2020, 01:15 PM   #1
avarshav
avarshav's Avatar
Drives: 2020 SS 1LE 6M, 24 Nissan Frontier
upgrading SS to ZL1 supercharger
ok, so I have a 2020 SS 1LE with a 6pd manual.
I have a good buddy who is in the process as we speak of upgrading his new 2020 ZL1 (with an auto) to the exorcist zl1 package at hennessey. yeah, I know....
anyway, here's what they do to his stock zl1..
http://hennesseyperformance.com/vehi...ercharged-zl1/
so I may have the opportunity to pick up all the parts that they take off his zl1 (a brand new zl1 with zero miles), including stock supercharger, stock heads, stock cam, stock lifters, valves, etc etc etc, what you see there.
i know enough to know that work is out of my ability, I freely admit that. so my question to the forum is, does anyone have an idea if what they take off that car can just be bolted on to mine, and I'd have everything I'd need to effectively have a zl1 motor in my car, understandably with a professional install and professional tune, or would I need to still spend a lot more on motor upgrades and transmission upgrades? Can that stock 6spd manual in the SS 1LE handle 650hp? I guess I'm trying to figure out how far from a ZL1 does that get me in parts, cause I may have an opportunity to pick up the parts they take off for very little, but if I need to spend another 15k in labor and parts to finish the job, then I'll go in a different direction.
does anyone have an idea of how much all those stock zl1 parts are worth and how much more it would take to get that SS to effectively have the same stock performance parts as the Zl1 and make that 650hp safely and reliabily, or is it just not possible? Previously I was never even thinking of doing this, but the opportunity to pick up these parts for beer money just presented itself, so I'm thinkin......
Looking for some genuine facts here guys.... thanks..
avarshav is offline   Reply With Quote
Old 09-05-2020, 05:09 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
ADM performance or Weapon X is pretty much the go to for LT4 supercharger conversion kits for the SS. They have posted plenty of info on it over the years in the forced induction section. I believe you are around 4500-5k for the complete setup with supercharger or 3500 for the install kit with everything needed.
Old 09-06-2020, 11:31 AM   #3
avarshav
avarshav's Avatar
I guess to better phrase my question....is anyone familiar enough with the exorcist package from hennessey to know whether all the stock zl1 parts that they remove are enough to build up an SS to that of a stock supercharged zl1? Would I need to add a lot of money in more parts for a complete build, or would it just be labor? I'm just trying to figure out how much more I would need to spend in this case...
Old 09-06-2020, 12:00 PM   #4
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Some things that come to mind you will need are innercooler pump, brackets, and complete wiring kit w/relay, adapter plates w/hardware, LT4 Balancer, Heat exchanger and reservoir tank, tuning. Probably another 2K in parts is my guess.
pauly1119 is offline   Reply With Quote
Old 09-06-2020, 12:23 PM   #5
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
You will probably never see the parts.......
3.8TransAM is offline   Reply With Quote
Old 09-06-2020, 01:10 PM   #6
avarshav
avarshav's Avatar
thanks, thats the kind of info I was looking for. will the lt4 supercharger fit under the stock ss hood?
Old 09-06-2020, 02:35 PM   #7
appleman22
Drives: 2017 1ss 1le
hahah I was thinking this! HENNESCREWED!!
appleman22 is offline   Reply With Quote
Old 09-06-2020, 02:37 PM   #8
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
LT4 blower is a great option especially for your situation. It is all GM...bolts right up. See my build thread in signature for a not quite blow-by-blow install/results (200 CHP increase!).
Tim M is offline   Reply With Quote
Old 09-06-2020, 07:57 PM   #9
Redlinez
Shifts under load
Redlinez's Avatar
Keep in mind you don't have the forged bottom end that the ZL1 does.
22 Suzuki GSX-S 1000GT blue
Old 09-06-2020, 08:54 PM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Very true Redlinez!
Old 09-06-2020, 10:43 PM   #11
avarshav
avarshav's Avatar
so you'd advise against it? or is an upgrade possible?
Old 09-06-2020, 11:08 PM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
And also 11.5:1 vs 10:1 compression ratio.
Old 09-07-2020, 04:29 AM   #13
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
As mentioned, it is possible to do this swap but, it's not a direct swap. You can't just simply bolt it on. It'll require an adapter to go from the blower to your heads. All things withstanding, so long as you have the parts needed to perform the swap, it's pretty straight forward.
But, please keep in mind that as someone else mentioned, you do not have the bottom end that a ZL1 has. Your stock pistons/rings are a gamble. You can get drop in pistons and be a bit safer but, it's all a roll of the dice. Keep it under 600whp, don't drive it like you stole it and you should be ok so long as you do proper maintenance and use quality fuels.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 09-07-2020, 06:13 AM   #14
Gary Frank
Drives: 07 Vette 19 Camaro92 350 S10
I had Vengeance put my friends Zl1 SC on my 2SS 19 M6.. It required a ADM kit and was straightforward. the LT1 will be safe below 650hp. the build came
me out fantastic looks stock. Performance is great 587rwt and 535rwhp with low 7lb boost.
Gary Frank is offline   Reply With Quote
