Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
What size socket needed to turn CAM after install?
I'm trying to check preload on my lifters so will need to turn the CAM to zero for each lifter. However, I tried all my sockets and none fit. I need to go buy one but would like to know the correct size to buy.
Thanks very much
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Aren’t you turning it with the crank/balancer Bolt?
Darth Martel
I assume that's the one
Darth Martel
The bolt I was looking to turn was the harmonic damper bolt which is now an aftermarket ARP bolt, 12 point, 1 and 1/16th inch socket. Is that the right bolt I should be turning?
Yes
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
quagmire Rings a bell with u.
Good Luck this time in fixing your build.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#7 |
Darth Martel
The good news is that both heads are back on after replacing the lifters. I'm just, hopefully, verifying that the provided pushrods are the right length and then I can put everything back together again. The use of aftermarket bolts for my build is a good thing but complicated things for me as I didn't have a 12 point socket set and I have to go get an 1 and 1/16th inch 12 point socket in order to turn the cam. Not.a big deal but, these things just add road blocks when I just want to get my car back together.
