Old 09-02-2020, 07:19 AM   #1
pumalex
Drives: 2020 Chevy Camaro
M6 transmission fluid?
Seems like we need some Dexron VI automatic fluid for our transmission, anyone tried an other brand? Found Redline D6 but is it any better than the OEM AC Delco? If you had to use a fluid for a race car, which fluid would it be?
thanks
pumalex is offline   Reply With Quote
Old 09-07-2020, 12:45 AM   #2
JayRow52
JayRow52's Avatar
Drives: 2017 Camaro 1LS 2.0T
I use Redline D6 in mine. I track the car casually (4 to 5 times a year) and do a trans drain and fill every spring. The Redline D6 has slightly better kinematic viscosity ratings than the OEM AC Delco fluids - 6.3 vs 5.8 - and should hold up better at higher temps. Although I’ve never had an issue with my trans fluid breaking down, I have seen trans fluid temps as high as 286* F after a 20 minute track session. I don’t have the trans cooler so that heat tends to linger, and running quality fluids is imperative.
Modifications: 1LE (FE3) Suspension, Chevy Performance 4-Piston Brembo Kit, Kansei Corsa wheels w/ Pirelli PZ4 265/45r18
JayRow52 is offline   Reply With Quote
Old 09-07-2020, 08:19 AM   #3
Redlinez
Shifts under load
Redlinez's Avatar
I will be using the Tremec fluid. https://www.tremec-store.com/collect...smission-fluid
22 Suzuki GSX-S 1000GT blue
Old 09-07-2020, 01:28 PM   #4
pumalex
thanks guy, might give the redline a shot
