Go Back   CAMARO6 > Marketplace > Members Classifieds > Forced Induction
Old 09-02-2020, 01:44 AM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Sold
Basically a complete working kit minus wire and maybe relays/toggle switches. Msd kit has like 6 passes on it, winmax is newly refurbished so the wires aren't cut. Everything works. Bottles have never been torched. The solenoids work but the stickers are torn/scratched
*NX 10lb bottle with billet adjustable bracket
*NX 5lb bottle with billet adjustable bracket
https://nitrousoutlet.com/i-30560208...le-single.html
*NX bottle opener. Works but rubber boot that hides the motor/wires is torn
*NX feed line
*NX fuel and other feed lines
*NX straight fuel adapter fitting
*NX n2o solenoid
*NX fuel solenoid
*NX bottle pressure guage
*Zex purge solenoid
*NO MSD hardline plate kit w/e85 jet kit
*NO Winmax window switch
*NO x series 10/15 lb bottle heater with pressure regulator
*JMS throttle position pigtail harness (no cutting the short wire by your pedal)
Whatever switches/relays and other misc things I have left I'll throw in the box as well.
Kit works great, just decided it's not for me. Asking 800
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 09-12-2020, 12:57 PM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Not good to mix different companies with NOS. So mixing can cause a problem, unless your system is divided up with only same companies parts but do see a mix.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
