Old 08-30-2020, 11:35 AM   #1
chris227
chris227's Avatar
2019 2SS Bluetooth and Nav issue
Just noticed last week that bluetooth will no longer pair. I push to connect phone and it does nothing. all previously connected phones show on the not connected section, clicking them does nothing. I had deleted all previously connected phones when i purchased the car used 5 months ago. All the phones that show are the ones i deleted. This is really strange. I am unable to delete any of them.
My Nav has GPS signal,it shows where i'm going no problem, i am unable to find any address anywhere though, no POIs, nothing.
If i try to enter my home address it says nothing found. No matter what i search it says that.
When i try to create a driver account, it doesn't find my email i had used previously, when i attempt to create a new account, i get server cannot be reached try again later.
I can connect to my home wifi, that's no problem.
This is driving me nuts, my last update to software shows as 2018. always says no update available when searching for update.
I have checked every fuse, pulled all fuses related, disconnected battery for hour. Nothing has helped. Checked all plugs on the hmi, Nav, antenna.
everything is connected fine.
Just wanted to see if anyone has ever has similar issues.
Thanks guys
Old 08-30-2020, 01:24 PM   #2
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Strange...
I don't have the factory Nav, so no insight on that, but try forgetting your Camaro in your phone's Bluetooth settings and re-pairing. Restart the phone too.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 08-30-2020, 02:07 PM   #3
chris227
chris227's Avatar
Originally Posted by PnCRedJwl2SS View Post
Strange...
Problem is it won't do nothing when I push to add phone. Nothing. This is not a phone issue at all. Wont even attempt to pair.
Old 08-30-2020, 03:02 PM   #4
FlyingFischer5
FlyingFischer5's Avatar
Drives: 2019 Camaro 2SS Satin Steel Gray
I would check with a local dealer. Sounds like something with software is messed up. I've had my '19 for 6 months and have had 3 software updates since owning it. I've only had one time my phone would not connect and I turned the car off and back on all all was good again. Or if you don't want to go to the dealer there is a "reset" in the settings. Can't remember where exactly but know I've seen one. Maybe give that a shot.
2019 Chevy Camaro - 2SS - Satin Steel Gray Metallic - RotoFab w/Dry Filter and Sound Tube Delete, Borla S-Type Carbon, Mishimoto Catch Can, (2) Banks iDash Gauges in ZZP Pillar Mount, DD Side Marker Lights, EOS Gloss Black ZL1 Splitter, Ikon Gloss Black Rear Diffuser
2004 Chevy Trailblazer - LS 4.2l - Black - 3.5" Lift, Custom Interior, Custom Roof Rack and Grille w/Built-in Light Bars, 285/55R20 on Trailblazer SS Wheels
FlyingFischer5 is offline   Reply With Quote
Old 08-30-2020, 03:09 PM   #5
chris227
chris227's Avatar
Tried the reset several times. Will be checking with dealer next week. Sucks cause its used and past the bumper to bumper warranty. When I connect phone with USB I get a constant connect/disconnect sound 5 or 6 times then just stops. Will not connect to Android auto. I play my music through USB thumb drive that stays connected all the time. It works fine. Odd
Old 08-30-2020, 04:23 PM   #6
supersportss
Drives: 2019 SS
Does your nav have a memory card, if so take it out with the ignition on and then reinsert and see if it reboots.
supersportss is offline   Reply With Quote
Old 08-30-2020, 10:17 PM   #7
chris227
chris227's Avatar
Tried that as well. Seems to be a communication issue. I have a appointment set for 7:30 tomorrow. Will update once I know something.
Old 08-31-2020, 07:14 AM   #8
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Turn off wifi on your phone.
overdriv is offline   Reply With Quote
Old 08-31-2020, 11:16 AM   #9
chris227
chris227's Avatar
Phone is not the problem. Clicking the add phone button on the screen does nothin just blinks. Changed my appointment to Fri, just got more important things to deal with right now. Frustrating to say the least.
Old 08-31-2020, 11:42 AM   #10
overdriv
overdriv's Avatar
My 2019 2SS will choke if both Bluetooth and WiFi are turned on on my Android phone.
If I turn off WiFi, it will connect after I unplug phone, reconnect phone it will make a couple of noises and soon AA will light up blue. I touch it and within 5-10 seconds WAZE will appear and Pandora button will show up.
My 2020 Silverado does not care if BT and WiFi are on at same time.??
Old 08-31-2020, 12:57 PM   #11
ember1205
Hot Camaro
ember1205's Avatar
Update the software in your car, and also check to ensure that your Android Auto app on your phone is not waiting on any pending updates.
OP: Seems you bought the car used - Did you ever check to ensure that OnStar knows that the car is no longer in the hands of the original owner? It's almost like they disabled all of the connectivity for your car...
Old 08-31-2020, 07:32 PM   #12
PnCRedJwl2SS
Howdy! Pete here...
Glad you are taking it in to the dealership. Should be covered under warranty.
PnCRedJwl2SS
Ordered from GM
Old 09-04-2020, 10:41 AM   #13
chris227
chris227's Avatar
Dealer is looking at car now, radio programming shows "unknown" tech is trying to figure it out.
Update.. Everything is working fine now, except the navigation, tech thinks it might have to do with sd card. Honestly don't care. everything else works. Tech had no
idea how the "unknown" software got on there or what caused it.
I'm now updated to the newest release. V808
