Old 08-30-2020, 07:57 AM   #1
Vee-Ate-Kameiro
Drives: 2018 Chevrolet Camaro 2SS
Run flats and non run flat tires
Hi,
Right now i have run flats for all 4 tires and I've had some back luck with tire punctures (nails, screws, etc.). I'd rather buy 2 non-flat tires for the front now (because 1 tire is leaking air) and then 2 non-flat tires for the rear in the future when the current rear run-flat tires get worn out. I've read online that they don't recommend this but if I'm daily driving it (not taking it to the track) is it an issue doing a front non-run flat/rear run flat combo?
Also any suggestions on non-run flat summer tires would be great!
Thanks
Vee-Ate-Kameiro is offline   Reply With Quote
Old 09-01-2020, 06:45 AM   #2
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Mixing tires I hear is not good. The run flats run considerably harder. Change to non run flat all around....
Old 09-01-2020, 06:54 AM   #3
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Mixing on the same axle is not bad and that's not what you said but sometimes get's confused. The not-recommended to mix front/rear isn't ideal but the grain of salt is that the recommendation comes from people who sell tires. It's "best or better" to replace in set's of 4 but it's not a make or break rule.
