Old 08-29-2020, 02:19 PM   #1
Brorker23
Drives: 2019 Zl1 Vert
Brian Tooley Stage 2 cam
I have a 2019 Zl1 Vert I just did Nick Williams 103 Tb
Magnuson 2650 supercharger Brian Tooley Stage 2 cam
Johnson lifters Kooks long tub catless and Borla attack
Dsx fuel kit plugs wires push rods and so on
My problem is the car wants to Jump in the middle of the intersection
When I'm stopped I have 10 speed auto
Has anyone had this issue with this cam
The shop that tuned my car is a very well know Hogh performance
Shop
They said my cam is too aggressive.
If I change my Tourqe converter Im wondering if this will help
I put down 801 on 93 oct and 895 on 100 oct
Brorker23 is offline   Reply With Quote
Old 08-29-2020, 04:33 PM   #2
IneedAZ
IneedAZ's Avatar
Others have used that cam without converter change. Is there another shop that could look at your tune. Also, did they do your trans tune? I am going with same cam along( pretty much same setup) and I spoke to BTR and they said it works with stock converter. Stage 3 they said needs a higher stall.
Old 08-29-2020, 04:55 PM   #3
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
I have a VR stage 2 cam with a 32% fuel lobe. Curious to your specs.
My car does not act like that all.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 08-29-2020, 05:22 PM   #4
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Do you mean the car wants to lunge forward?
If so then it sounds like it’s tune related.
Old 08-29-2020, 07:18 PM   #5
Brorker23
Yes my tcm has been programed. The shop said they would try and re tune the car but insisted its my cam
Old 08-29-2020, 07:19 PM   #6
Brorker23
That's exactly what it does
Old 08-29-2020, 07:38 PM   #7
IneedAZ
IneedAZ's Avatar
Wish I could help you out. If mine was finished we could compare tunes.
Old 08-29-2020, 07:51 PM   #8
Brorker23
[ATTACH]Name:  20200829_184621.jpg
Size:  118.2 KB[/ATTACH]
My cam has 38% fuel lobe
Old 08-30-2020, 03:09 AM   #9
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
I have Weapon-x cam with nearly same specs & I have stock converter, the car accelerates from a stop by itself upto 1300rpm.
Ted@JRE told me the big with stock converter causes this & he adjusted it in the tune .
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 08-30-2020, 06:31 AM   #10
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
That is a moderately aggressive cam per the specs, but they are not beyond the ability of a quality shop to tune for decent drivability on street.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 08-30-2020, 08:13 AM   #11
laynlo15
Drives: 2022 Lt1 A10
I had a BTR in my 16 Camaro with 2650 and never had any issues with mine. Actually drove really well. I would think its in the tuning.
Old 08-30-2020, 09:11 AM   #12
Brorker23
They told me from the beginning that is was an aggressive cam and it might have a little drivability. I never imagined this tho...
I believe its in the tune . They are one of the best performance shops
In the Midwest but other have complained about there tunes lately as well.
I will give them the befit as they been straight forward with me on dyno numbers pricing for labor and parts pricing
I will let them try and re tune it and see what happens if not I will try someone else
If anyone is in the Midwest and know of a good tuner I would appreciate it
Old 08-30-2020, 09:21 AM   #13
IneedAZ
IneedAZ's Avatar
Which stage did you use?
Old 08-30-2020, 09:23 AM   #14
IneedAZ
IneedAZ's Avatar
I will let them try and re tune and see what happens if not I will try someone else
You may want to call BTR tomorrow and verify what I said before in my earlier post that stage 2 should be OK with stock converter.
