Old 08-27-2020, 09:49 AM   #1
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
GM Solid Cradle Bushings (In-stock)
I got an email this morning that gmperformancemotor now has like 20 kits in stock, for those still looking to make the upgrade. Hope this helps someone!
https://www.gmperformancemotor.com/P..._Code=84341929
driven2exceSS is offline   Reply With Quote
Old 09-03-2020, 07:53 AM   #2
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
S.O.B I've been waiting for these things and of course they are back in stock when I just spent that money on a track day lol
That1guy_tim is offline   Reply With Quote
Old 09-03-2020, 09:53 AM   #3
Perfect excuse for the next one
Old 09-03-2020, 08:38 PM   #4
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
21st? What class you running?
aronSlusa is offline   Reply With Quote
Old 09-03-2020, 11:08 PM   #5
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Use a CC damn it. Don't miss out on picking some up while they are available. Hold on to them for a while if you need to wait on the install, but at least get them, they aren't that expensive.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 09-04-2020, 12:19 AM   #6
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Ordered! Not looking forward to the labor, but these are cheaper and better vs BMR imo. Don't want to miss out.
Thanks driven2exceSS!
Old 09-04-2020, 10:08 AM   #7
driven2exceSS
Glad to help
Seriously once you are done, looking back at the labor around the install, it will not be as bad as you initially anticipated. At least that was the view I had afterwards.
Old 09-05-2020, 11:32 AM   #8
L78toLT1
L78toLT1's Avatar
Don't fear the install, Dave. My bushings languished on the shelf for a month or so until i worked up the resolve to do the install. Just drop the cradle completely down and use the two-jawed puller technique to press out the old bushings and the rest is cake. I let my solid bushings cold soak in the freezer overnight also. Probably not necessary, but may be of some benefit.
Baby Blue
Old 09-05-2020, 01:00 PM   #9
DaveC113
DaveC113's Avatar
Thanks for the encouragement! I've struggled with chassis and suspension bushings on some past cars, they can be really stubborn, lol... But I do have a small-ish press and a 2-jaw puller, if the puller worked then I'm not too worried. I'll have to see if I can bring it into a friend's shop to use the lift though, not sure i want to this one on jack stands.
Old 09-05-2020, 02:42 PM   #10
20Bluezl1
I'm going to take the risk and try to do them with my quick jack. Hopefully I have enough room.
Old 09-05-2020, 03:00 PM   #11
L78toLT1
L78toLT1's Avatar
It's not bad on stands but a lift is always nice. You need a stout 1/2" impact gun to use on the puller, it took probably a solid minute or so for each bushing, but they all came out perfectly intact.
Baby Blue
