Old 08-26-2020, 09:59 PM   #1
JFWJR179
JFWJR179's Avatar
Drives: 2022 Camaro ZL1 Convertible A10
Katech ZL1 LT4 Wet Sump Oil Pump
Does anyone know the status of the Katech LT4 wet sump oil pump that is being developed, that should fix any problems with the factory LT4 oil pump
I telephoned Katech in July 2020 and they said it was coming soon.
JFWJR179 is offline   Reply With Quote
Old 08-26-2020, 10:06 PM   #2
Busted43
Busted43's Avatar
Drives: 2018 zl1,A10,16 GLC300
On 8/20 they posted on the failed oil pump thread to stand by for an announcement soon.
2018 ABM,A10
Kooks 2” headers no cats, NW 103 Tb, Kong ported blower with 2.31 pully, Elite E2x catch can, Cordes under hood expansion tank, Flowmaster axle back, Rotofab dry filter,Mustang Dyno # 647whp/674wtq.
Busted43 is offline   Reply With Quote
Old 08-26-2020, 11:23 PM   #3
CaliforniaKid
Drives: 2018 ZLE
Subscribed!
CaliforniaKid is offline   Reply With Quote
Old 08-27-2020, 06:48 AM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Shoot Zach at Katech an email. He posted a reply in the oil pump failure poll in the ZL1 section of the forum on page 39.
Old 08-27-2020, 07:54 AM   #5
IneedAZ
IneedAZ's Avatar
Be nice to have info on in next week or two max. Only thing holding up my build is the 2650. Apparently there is a rotor shortage, so my 2650 is held up. I am replacing my oil pump and at this point with oe GM latest part number pump unless Katech shows what they have to offer.
Old 08-29-2020, 05:13 AM   #6
AZ_1LE
Drives: 2019 ZL1 1LE
GM worked with Melling and fixed the issue. There have been around 6 part number revisions. No need to wait for Katech.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 08-29-2020, 09:14 AM   #7
LT4Greg
LT4Greg's Avatar
My thoughts too AZ_1LE!��
Old 08-29-2020, 10:00 AM   #8
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
When was the most recent revision completed? Source?
ZX-10R is offline   Reply With Quote
Old 09-01-2020, 07:21 PM   #9
jjgi5150
Drives: 2022 ZL1 1LE
Hi...
Just wondering if you confirmed this info from someone at GM or Melling. I realize there were part number changes, several of them, so how are you sure the latest P/N will be the cure?
I want to keep my ZLE, but l believe l'm in the build range that will likely fail. I have no desire to spend $800+ dollars for an aftermarket unit, plus labor, to fix what GM and Melling messed up. So l guess l'll be stuck waiting for a failure and hoping GM sends new, latest version of this disaster.
Any info you can verify will be appreciated.
JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!!
2021 F-250 FX4
2023 Hyundai SF Calligraphy
jjgi5150 is offline   Reply With Quote
Old 09-02-2020, 12:24 PM   #10
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Originally Posted by jjgi5150 View Post
Hi...
JJ
When you say "...l believe l'm in the build range that will likely fail...." is there data that says that greater than 50% of cars between X-Y build dates are failing? I haven't kept track of this info.
I thought the percentage was very low so most cars even during that build range are very likely not to fail, but some have.
SFV1LE is offline   Reply With Quote
Old 09-02-2020, 12:32 PM   #11
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Here is a general idea of build dates and failures.
https://www.camaro6.com/forums/showthread.php?t=532479
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 09-02-2020, 01:25 PM   #12
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
You are correct. There is a date range when there legitimately seems to be a higher rate of failure. But, to think that every LT4 produced in that ~6 month window has or will fail seems to be a stretch. We would be seeing thousands of blown LT4 if this were the case.
DFW_Muscle is offline   Reply With Quote
Old 09-02-2020, 01:29 PM   #13
DFW_Muscle
I agree with using OEM over an unproved aftermarket option.
That said, I do want to point out that GM changes part numbers on parts all the time. A part number change does not mean the part was revised. The 6 part number changes on the pump doesn't mean it went through some physical revision change each time. I think that's somewhat of a misconception.
Old 09-02-2020, 02:10 PM   #14
AZ_1LE
Hi...
JJ
The latest part number are what the latest LT4's are being built with, and there have been no reported issues with them.
I read online almost a year ago that GM was working with Melling (their supplier) but I don't remember that exact site.
Old: 2017 SS 1LE
Old: 2017 ZL1
