Old 08-26-2020, 09:59 AM   #1
Billabongi
Billabongi's Avatar
Drives: '17 SS 50th Camaro
255/285 SS Tires
Hey guys, there is a national backorder on the stock 245 Michelin P4S's and I wanted to run a slightly wider tire anyway so I went ahead and ordered 255/285 setup vs the stock 245/275.
I've seen several folks on here run this setup without issue but I'm getting a lot of push back from tirerack and firestone saying the tire is taller and the speedo will be off.
Speed is off 1.1% which I'm fine with but I guess I'm just trying to triple check anyone running this setup has not run into an issue.
Appreciate any advice here.
Thanks,
James
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410
Billabongi is offline   Reply With Quote
Old 08-26-2020, 08:25 PM   #2
I ran this exact setup for a few thousand miles with zero fitment, drivability, ABS, stabilitrak etc. issues. If anything, it looks even better with the stock wheels, just go ahead. Oh, and if you're switching from the stock runflats, you're in for a treat.
Old 08-26-2020, 09:50 PM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Yup. You’ll be fine. I’m running PS4S in 255 and 295 on aftermarket wheels. No issues for over a year. Speedometer is off slightly but only a few mph.
Old 08-27-2020, 01:05 AM   #4
Billabongi
Billabongi's Avatar
Thanks guys makes me feel better about going this way.
Old 08-27-2020, 06:17 AM   #5
Redlinez
Shifts under load
Redlinez's Avatar
I did it for 28,000 miles. Zero issues, drove great.
22 Suzuki GSX-S 1000GT blue
Old 08-27-2020, 11:07 AM   #6
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
That's good to hear. Did you track or autocross it with this size on it?
I've considered upgrading to the SS 1LE Supercar3 tires in this size on my regular SS.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 08-27-2020, 11:20 AM   #7
Redlinez
Shifts under load
Redlinez's Avatar
I did HPDE one weekend and it went great. I think a 305 would be too wide on the standard SS wheel. I had the 4S's as well.
Old 08-27-2020, 11:52 AM   #8
bdavies11
Thanks,
James
Been running 255/285's for the last 60,000 miles or so on two different sets of tires. Not a single issue yet other than the speedometer being a mph or two off.
bdavies11 is offline   Reply With Quote
Old 08-27-2020, 09:33 PM   #9
Billabongi
Billabongi's Avatar
Whoa that’s the most I’ve heard of. Awesome!
