![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Zl1 fluid temps
So I've been searching for the max temperature of all fluid s on the zl1 A-10 non 1le not sure if they would run different temperature.
The reason I'm wondering is I have a i-dash and would like to setup with alerts just incase I run hot or something fails. I feel like my oil temp are a little high but again not sure. Note I'm always running on manual and high rpms. I beat the shit out of it probably like most of us do Sorry for the blurry picture I was moving pretty good . |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
Many of us have seen 250+. I was a bit stressed when I saw it for the first time.
I back off when I get close to 265-270. Multiple oil samples have shown no ill effect here. Bang on that thing!
2018 ZL1 1LE sw/PDR
Thank you hopefully other members chime in with max temperatures on all fluids like engine oil,coolant and trans oil.
Drives: 2018 ZL1 1LE Join Date: Jun 2020
Ive seen over 280 at the track, oil tests came back showing no ill effects toward the oil or motor.
![]() Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
Water 221
Oil 279 Trans 227 Afternoon track session at VIR on a hot day. Oil service indicator counts down in a hurry at those temps. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
290ish oil is the hottest for me
#7 |
Ok so I see tbe number are pretty high. Does anyone know at what temperature should be the maximum. I'm assuming there would be some warning light come on if your to hot.
#8 |
![]() Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
I had 280 at the track on a hot day but it didn't climb past that into the red. This is a 1LE with 15W50 in it so may not be relevant to your inquiry. I think the red line on my gauge is at 300.
#9 |
![]() Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
I had 288 on my last run of the day around 2pm here in northern Florida last weekend. 1LE with 15 50 as well. Outside air temp was just about 100.
#10 |
![]() Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
Max Fluid Temps ZL-1
This is from a recent track day:
Max Water Temp 225 Max Oil pressure 68 Max Oil Temp 277 Max Trans Oil Temp 219
Home Track: NCM Motorsports Park
#11 |
![]() Drives: 2019 Camaro ZL1 1LE A10 Join Date: Jul 2020
I'm not sure I would want to see 300. Oils I have tested in the 300 degree range have shown signs of breaking down
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Is everyone running with their coil covers off?
#13 |
#14 |
That was me.
