Old 08-23-2020, 06:41 AM   #1
Billabongi
Billabongi's Avatar
Drives: '17 SS 50th Camaro
A/C Hot Air at High Throttle
I’ve barely driven the car in the last few months but had it out this weekend. At WOT and anything close to it the car now blows hot air until I left off. I also generally feel like the A/C isn’t as cold as it used to be. The car would freeze you out in low but I had it there for a good 30 mins and while the air was cold it didn’t seem like it used to be.
Any ideas? Freon, vac lines or compressor maybe?
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410
Billabongi is offline   Reply With Quote
Old 08-23-2020, 08:29 AM   #2
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
A lot of cars de- energize the compressor clutch under WOT, this frees up a few HP. I believe the Camaro does this, but I’m not 100% certain.
As far as not cooling under normal driving conditions, these are the most common culprits:
Condenser fan not operating (engine bay)
Low refrigerant
Blend door stuck
I’ve seen quite a few people here with a non functioning condenser fan.
Old 08-23-2020, 08:33 AM   #3
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
that's by design and normal.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 08-23-2020, 02:48 PM   #4
Billabongi
Billabongi's Avatar
Interesting I’ve read the AC stays running on the 6th gen under WOT. I swear it didn’t do this before but may not have noticed it.
Old 08-23-2020, 05:50 PM   #5
weatherman71
Drives: 2019 Camaro 2SS
the ac compressor isnt designed to spin at 6000 rpms.... its shut off at wot the preserve the life so it doesnt grenade on wot. almost every vehicle does it these days.
weatherman71 is offline   Reply With Quote
