Old 08-21-2020, 09:05 PM   #1
Nabush
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE
Katech Stage 2 engine : 552WHP 488 FTLbs
After all the issues I had with the TSP VVT3 + Ported heads... The GPI Stage 3 cam....
Katech is the best cam by far.
It idles like stock or almost (yes !) with correct tuning (at 750 rpm), no chop.
It makes excellent power and torque, in fact as much if not more as TSP and GPI stage 3 without the rough idle.
Config :
AFE CAI
95mm Ported TB Solers Performance
MSD Intake Manifold "house ported"
- Katech Ported heads
- PSI 1511 Beehive springs
- Titanium retainers
- GM LS7 lifters
- ARP bolting
- Katech LT1 Torquer cam 219/233 118 LSA 0.645-0.655 lift
- VVT limiter to 11deg
- Etc
DSX Flex fuel
ARH LT headers
X pipe with high flow cats
I probably left 10-15 Hp on the table because of time constraints on this dyno. I'm not an experienced tuner by any means, I just learned DIY
Honestly I think the heads/cam package from Katech is the best hands down. Torque all accross (410 FTlbs at 2500 rpm !! ) and great power up top, super driveability with a stable idle, like stock.
Weird point is I had to left the VVT at 0 deg until 6000 rpm (so fully advanced) to get the best results, then after 6000 only 3 deg of retard gave the best results.
Nabush is offline   Reply With Quote
Old 08-21-2020, 10:13 PM   #2
OneSlowV
OneSlowV's Avatar
Drives: 2018 camaro ss
What issues you have with GPI cam ?
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved
OneSlowV is offline   Reply With Quote
Old 08-21-2020, 10:18 PM   #3
17camaroSS
17camaroSS's Avatar
Drives: Chevy Camaro SS
I’m with the above question. What issues did you have with the GPI?
17camaroSS is offline   Reply With Quote
Old 08-21-2020, 11:57 PM   #4
Nabush
Unexplainable dip of torque between 3500-4500, and noticeable weaker torque below 2500.
Had the same issue with the TSP Stage 3
It's almost like I needed to jump 1 tooth on the timing to advance the cam 8 deg. Dot to Dot was not working... Why, I can't explain... I did a test on the VTT with the katech and if I retard my cam 8deg I have exactly the same behavior. Dip of torque above 3000 rpm then catch up at 4500-4800 rpm.
It's like my crank sprocket was off or something...
Anyway, the Katech makes even more peak HP and has stock idle and torque from idle... It's probably also the result of the whole package with Katech mastering valve train control...
Old 08-22-2020, 12:08 AM   #5
pmoore4321
Drives: GMC Sierra
I did the same thing. I will only go mild cam from now on. Whatever I left on the table is not worth crappy idle, fuel mileage lost, valve train stress, etc. Latest cam I put in is 210/230 .529/.572 118. It made 580w on 8lbs (biggest pulley Whipple makes). This is on an UNOPENED 5.3 L83 truck. Stock heads, stock factory installed head gaskets. Slid the old cam out, slid the new on in. 15.1mpg honest mileage on E85 and idle at 725rpm. I do have the 38% lobe and LT4 fueling.
pmoore4321 is offline   Reply With Quote
Old 08-22-2020, 12:35 AM   #6
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Nabush: Thanks for posting...glad you found success in the updates - great feedback!
Tim M is offline   Reply With Quote
Old 08-22-2020, 05:54 AM   #7
Redlinez
Shifts under load
Redlinez's Avatar
Congrats! Glad you finally have something that's working well. Makes me wonder about the GMPP hotcam and heads combo.
22 Suzuki GSX-S 1000GT blue
Old 08-25-2020, 07:11 PM   #8
Bomicino
Drives: 2020 LT1
No to derail. But if bottom end tq and a "nice smooth" idle sounds desirable, GMPP is not for you.
Congrats OP, thats a lot of power without sacraficing drivability.
Bomicino is offline   Reply With Quote
Old 08-25-2020, 10:35 PM   #9
Nabush
Can't tell you what the GMPP Hotcam and head combo does...Never seen one installed or results...
Old 08-26-2020, 08:52 PM   #10
Redlinez
Shifts under load
Redlinez's Avatar
I actually like a loping idle, but I don't want to have an overcammed street car that loses its tail on bottom end torque and only realizes real gains way up top where I never am unless at a track. It's sounding a lot like what worked great in LS1's back in the day. Mid 200's duration 600 lift and whatever LSA works on these engines, a 112+2 or so with XE-R/XE lobe mix was great on LS1's. Almost think there needs to be a "small cam" thread for folks looking for daily driveability with significant gains that make the car more fun almost everywhere.
Old 08-26-2020, 10:04 PM   #11
7speed
Drives: 21 SS
I have the chevy hot cam waiting to be installed, I'm just trying to decide and see if will have $ for heads.
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 08-27-2020, 11:09 AM   #12
Nabush
I think the 118 LSA of the Katech cam helps the idle...
The GPI had 112 LSA and idle was crappy as hell
Old 08-27-2020, 11:14 AM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
if i keep my car i would love to do cams and e85 and heads and be around 500whp na !
Old 08-27-2020, 11:48 AM   #14
Nabush
Definitely a big leap forward in terms of performance.
