BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Intake Manifold question
What is this sensor called that plugs into the intake manifold on the passenger side right behind the throttle body? The hose that is connected to it and runs up next to the engine cover came disconnected at the junction near the firewall. I think that's why I've had idle issues and hesitation. I don't knoe how it came unplugged but I noticed it when I was installing my ported IM.
I posted this in General Discussions but probably should have put it here. |
Evap.
#3 | |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
#4 | |
BL1ZZRD
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Does anyone know where to get a oring for this thing?
Mine ripped
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
something to consider. i had a vacuum leak at the sensor on both msd intake manifolds.
#7 |
In that case a dab of gasket maker might be better
#8 |
mine was caused by the sensor not sitting in the port correctly. i had to add a spacer between the manifold and sensor for the bolt to go thru.
#9 |
![]() Drives: 2019 2SS 1LE Camaro Join Date: Oct 2024
