2020 Shadow Gray 2SS
Just got a Range AFM Delete module for my 2020 2SS, on the back of the box it says "IMPORTANT: Do not leave your Range device installed on a vehicle that is not driven daily. Unplug the device if the vehicle will not be driven for a few days. There may be a draw on the battery in some vehicles."
My question is, is there a battery draw on the Camaro SS if you leave this device plugged in? There I times I might go 7-10 days without driving my Camaro, will this cause a battery issue? Any feedback would be much appreciated!
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
Retired from Car mfrs....
Supposedly the newest range devices do not drain the battery to any great degree. Contact range for more definitive facts.
Thanks, mine should be the newest as I ordered it directly from Range and it was even backordered a couple days when I ordered it...
![]() Drives: 2018 Camaro 2SS, redline edition Join Date: Jun 2013
On their page, they state it still draws a very minimal current.
See below for the quote: "Testing has shown that the Range Device has a very small battery draw when the vehicle is off and in "sleep" mode. This is because it needs a monitor running to catch when the vehicle is started. This small draw is not enough to adversely affect battery life or drain the battery unless left in place for an extended period of time (i.e. more than a week or two)." |
#5 | |
I would. It does not hurt to remove it. I unplug mine daily in the summer time because my car sits in the Sun all day and it gets hot in the car. I've had no problems removing it daily. Nothing has loosened and it works great.
#7 |
![]() Drives: SWXXZL1 Join Date: Jul 2020
You can remove it or utilize a switchable harness. One end goes into the OBDII port and the other end has the RANGE MODULE plugged into it. In between is a simple rocker switch. The one I bought is 24" long which allows for the module to be placed under the dash or near the console.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I left mine (#RA003G, V8.6R1) plugged in all the time, but my C7 Z06 was always on a BATTERY TENDER PLUS when the car was stored. Removing it over and over risks bending a pin. |
#8 | |
Just ordered the harness.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
You will be good with the harness, I have been usi ng my Range with a harness for yeays, always switch it off if the car will sit for more than a few minutes, never had an issue.
#10 |
Where are you guys mounting the switch and device??? I haven't looked under the dash yet but I don't want wires hanging everywhere...
#11 |
This is how I have mine mounted. I used velco for the Range on the carpet as well as the switch itself.
#12 |
Nice! Thank you!
#13 |
Thanks for all the feedback, guys!
Got my Range AFM Delete and Switch Harness installed today!
