Old 08-16-2020, 07:46 AM   #1
Lobster catcher
Drives: 2017ss camaro convertible redline
Pulled to the right a couple times
I was out raising a little hell last night and this awesome handling car felt like it was going to get away from me .once was on a road that was not real flat I get that.The other time I was going about 50 in 2nd gear on a good flat road and I nailed it and it wanted to yank me to the right before I shifted to 3rd . Another time I was in track mode around 125 mph and the car got unstable feeling I just let off the gas and let her slow up I’ve been at this speed and more before and car felt fine but something has changed.Im hoping it’s the tires they have 30000 miles on them any feed back would be great
Lobster catcher is offline   Reply With Quote
Old 08-16-2020, 08:14 AM   #2
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Check the front wheel lug nuts, axle nuts, and jack it up or put it on a lift and look at the front suspension. Pay close attention to the adjustment points for the front suspense. Those movements are not right and you need to find it or bring to the dealership to find. You should keep your foot out of it unit it figured out. Be safe.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 08-16-2020, 09:25 AM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Sounds like to me from your description that your rear tires may be worn out especially if they have 30,000 miles. And as He11bent said, be safe out there!��
Old 08-16-2020, 10:14 AM   #4
JROC
Drives: 19 Camaro SS 1LE, 03 Ford Lightning
I was thinking worn tires as well.
A C6 Z06 making 500+ WHP might feel great with some new R888's on it, but you try and push it with some wornout runflats and you'll quickly start thinking it's an uncomposed, POS Mustang.... Ummm I mean crowd dart.
JROC is offline   Reply With Quote
Old 08-16-2020, 12:24 PM   #5
Lobster catcher
Thanks I’ve got some Michelin pilots on order I’ll have the dealership check out the suspension all the way around and do a front end alignment on it and go from there I’ll stay off the gas until not a good feeling something isn’t right.
