Old 08-14-2020, 09:56 AM   #1
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
275/40/19 or 285/35/19
Looking at these two size tires for my 2017 SS on my new wheels. 19 x 9.5 +25
The 275/40/19 actually keeps closest to the stock diameter.
Any experience with these.... Thanks in advance...
Old 08-14-2020, 10:21 AM   #2
enzia35
Drives: '16 Garnet Red 1SS
For 9.5" tires...
https://i.stack.imgur.com/jHVET.png
'16 Camaro 1SS
'18 Miata GT
Old 08-14-2020, 10:31 AM   #3
VinnAY
Drives: 18 1SS/1LE
Ya you're wider than the recommended width's there if that matters to you. That 285 contact won't be "285" when mount on a rim that is too narrow for it. Can be done, not recommended probably. 9.5 was a poor choice if you wanted wider tires.
Old 08-14-2020, 11:02 AM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
The 9.5 inch width will fit a 275 tire no issue and still be in the recommended widths.
Old 08-14-2020, 12:57 PM   #5
VinnAY
Drives: 18 1SS/1LE
so why are you here
Old 08-14-2020, 02:23 PM   #6
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Originally Posted by VinnAY View Post
so why are you here
Tapping into the Camaro6 knowledge base....
Old 08-14-2020, 03:02 PM   #7
enzia35
I'd prolly go for the 275/40/19.
'16 Camaro 1SS
'18 Miata GT
Old 08-16-2020, 12:29 PM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
You should also look into the load ratings, and if possible avoid using a tire with a lower load index than whatever your car's OE tire size(s) were.
XL and SL load indexes are not the same (this matters), and small differences in rated load can be accommodated via slightly different inflation pressures. A 275/40 is actually a bigger tire than a 285/35-19 in terms of load capacity at any given pressure is concerned
Norm
Old 08-25-2020, 10:36 PM   #9
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Michelin's website says 285/35/19 will fit on a 9.5" rim; that is actually the min. recommended width, so assuming whatever tire you buy is similar, there's likely no issues there.
That said, the 285/35/19 are 0.8" smaller diameter than the 275/40/19, and therefore your fender/wheel gap will get larger due to the smaller tire, and your speed will be off if the stock height is closer to the 275/40/19. Additionally, for a given width, a smaller diameter tire has a smaller traction patch, so the actual gains of going to the 285 would be somewhat offset by the 35 profile compared to the 275/40.
I would like 285s but don't want the smaller dia. tire, I wish they made a 285/38/19 - I'd buy that.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 08-27-2020, 07:03 AM   #10
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
I am definitely ordering the 275/40/19 's and they are VERY close o the stock diameter....
Old 08-30-2020, 08:32 AM   #11
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Ordered the Firestones and new TPMS....
Old 08-30-2020, 09:17 PM   #12
Markoz28
Drives: 18 ZL1 nightfall grey A10
Wider is better. 275 is too narrow and from the rear looks like a base V6
Markoz28 is offline   Reply With Quote
Old 08-31-2020, 08:30 AM   #13
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
275 is the stock width.
Old 09-04-2020, 08:10 AM   #14
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Tires and wheels are mounted. No issues...car is dirty will get it cleaned up.
