Old 08-12-2020, 08:26 AM   #1
HavocZL1
HavocZL1's Avatar
Drives: 2020 Camaro ZL1
Best Fluid for TR-6060 in 2020 ZL1
Struggling here - Tremec HP Fluid, Royal Purple Synchromax, or something else? Not for track - just aggressive street driving. Would LOVE some clarity on this! Thanks.
HavocZL1 is offline   Reply With Quote
Old 08-12-2020, 09:09 AM   #2
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I used Royal Purple because it seemed like most people were recommending it because it made a very noticeable difference in shifting. Not much of a difference in my car.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 08-12-2020, 09:20 AM   #3
hammerdahn
Drives: 19 ZLE
I've been using AMSOIL ATF for the past 4k miles. It improved notchiness and ease of shifting.
hammerdahn is offline   Reply With Quote
Old 08-12-2020, 09:29 AM   #4
ZLE dude
Drives: '18 ZL1 1LE
I'm planning to put RP Synchromax in mine in a few weeks. I'll report back if it improves the 1-2 notchiness as I've heard that it helps with this. We shall see.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 08-12-2020, 09:32 AM   #5
HavocZL1
HavocZL1's Avatar
That’s what I’ve been hearing as well. Just wanted to make absolutely sure it’s meant for the TR-6060 in our cars...
Old 08-12-2020, 12:46 PM   #6
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
ATF in a manual? I've seen this before on Amsoil's website. Confusing, isn't it?
MartinLe is offline   Reply With Quote
Old 08-12-2020, 01:10 PM   #7
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
TR-6060 uses Dexron III fluid which is an old ATF standard. GM's manual trans fluid for TR-6060 is just renamed Dexron III ATF.
Make sure you get the Amsoil Signature Multi ATF and double check the standards(compatible with Dexron III) on the bottle. I have it in my trans right now and it works pretty well.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-12-2020, 01:17 PM   #8
MartinLe
MartinLe's Avatar
Thank you.
Old 08-12-2020, 02:42 PM   #9
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
honestly i had swapped mine out to both Royal Purple and Redline. honestly the best turned out to be FRESH OEM.
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
Old 08-12-2020, 04:02 PM   #10
travislambert
Drives: '17 ZL1
For street driving why not stick with the stock fluid? Other than a stubborn cold shift every once in a while, it's actually pretty darn good.
I never had an issue with the stock fluid until I learned to really push the limit of the car on the track. I then found myself having to wait on the synchronizers during downshifts. Changing the fluid would fix the problem for a couple of hours of track use, then I would start noticing more and more delay on downshifts again.
I switched to the Tremec brand fluid at the beginning of this year and it has been perfect ever since.
travislambert is offline   Reply With Quote
Old 08-12-2020, 06:06 PM   #11
HavocZL1
HavocZL1's Avatar
What are your thoughts on the Royal Purple Synchromax? So bizarre that you can use ATF in a manual...
Old 08-12-2020, 06:07 PM   #12
HavocZL1
HavocZL1's Avatar
I never had an issue with the stock fluid until I learned to really push the limit of the car on the track. I then found myself having to wait on the synchronizers during downshifts. I changed the fluid which would fix the problem for a couple of hours of track use, then I would start noticing more and more delay on downshifts again.
That was my thought - Wouldn't tremec brand MTF be the best for a Tremec transmission?
Old 08-12-2020, 06:14 PM   #13
travislambert
Drives: '17 ZL1
That was my logic. Other fluids may work great, but I figured there is always a chance of an incompatibility with a chemical and a material inside the transmission causing premature wear. With OEM fluid and fluid direct from the transmission manufacturer I feel like that risk is minimized.
Since the OEM fluid was falling a little short, the natural choice for me was to try the Tremec fluid. So far, I couldn't be happier.
Old 08-12-2020, 06:28 PM   #14
HavocZL1
HavocZL1's Avatar
Cool - what was it that you used? Tremec HP? I feel like that's the safest way to go.
