08-09-2020, 10:55 AM | #1 |
Drives: Chevrolet Malibu Join Date: Oct 2008
OEM GM Factory 1LE Splitter
I have a GM 1LE splitter, brand new in box. I only opened the box to take pictures. It came with my 2013 1LE but was never installed. I no longer have the car.
$500, local pickup only. I am in Raynham, Massachusetts. Last edited by bucklwi1; 01-16-2021 at 07:49 PM. |
08-09-2020, 12:53 PM | #2 |
Here are some pics
08-09-2020, 11:21 PM | #3 |
Youre missing a lot of parts to this Fascia package to ask for $600. You only have the front splitter right?
08-10-2020, 12:08 AM | #4 |
GM Parts Direct
Fascia Pkg - GM (22950575) List Price: $1,059.28 You Save: $369.69 (35% off) Sale Price: $689.59 Core Charge: $75.00 ADD TO CART Buick, GMC, Cadillac, Hummer, Saturn, Oldsmobile, Pontiac, Chevrolet Parts Manufacturer: GM Part Number: 22950575 Part: Fascia Pkg Replaces: 23109510
08-12-2020, 08:45 AM | #5 |
Drives: 2011 Synergy Green 2SS/RS Join Date: Jun 2014
What is bottom package in plastic ?
08-12-2020, 02:57 PM | #6 |
Let me know if you change your mind about shipping.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
08-12-2020, 04:31 PM | #7 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Looks like the mounting kit for the front and sides.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
08-13-2020, 04:16 AM | #8 |
So the splitter will fit on 2010-2013’s SS’s models an if I remember correctly the RS fascia on a V6 car will also work. A base V6 it will not fit.
Orange Krush II
08-13-2020, 07:50 AM | #9 |
Drives: 2013 Camaro SS 6-Speed Join Date: Nov 2017
Not to bust on your post but cant you get the same thing on ebay for $100?
2013 Camaro 1SS 6-Speed LS3 All stock.. For now... |
08-13-2020, 11:41 AM | #10 |
What Ive seen on ebay is usually their stuff is garbage. For instance, There was a rear spoiler that looked good that I wanted. I noticed there were no mounting bolts. When I told the seller that my car sees speeds over 150 mph, he told me his wouldn't be able to stay on the car. LOL. obviously. For the most part, you get what you pay for in the parts world.
08-13-2020, 04:38 PM | #11 |
What’s in the other packages .might be interested and I’m local
Any other pics |
08-13-2020, 09:36 PM | #12 |
The other bags contain the mounting clips and an hardware these OEM 1LE splitters are hard to come buy even back in 2013-14 and they were 400-500 then,I think a more reasonable price would be 350 shipped.
Orange Krush II
08-18-2020, 09:08 PM | #13 |
Kevin Silvia 508 324 5505
PM me I’d like to check it out |
08-19-2020, 04:53 AM | #14 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
Message me if you will split the mounting hardware and splitter.
