Old 08-08-2020, 07:09 PM   #1
17MaroSS
Drives: 17 2SS 6sp
Launch technique for m6 ss?
Hey guys and girls
So what's the best way to launch these things? Please describe your technique. Thanks! Bone stock car including tires.
17MaroSS is offline   Reply With Quote
Old 08-09-2020, 02:03 AM   #2
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Just my personal preference... sport mode on dash and set suspension to tour mode through infotainment settings.. I feel like it squats a lil better and hooks more..... other then that, I rev at 3500-4000 depending on conditions (rough, smooth, hot, cold surface) smoothly but semi quickly letting off clutch while at same time trying to manage slip but get to wot as quick as possible
Dvs510 is offline   Reply With Quote
Old 08-09-2020, 10:34 AM   #3
6spdhyperblue
Drives: 2SS 1LE
Stock tires - suspension locked to tour. Track setting because you want the slower throttle map to help pedal the car out.
If it’s a slipnslide u have to slip the clutch from 1800 rpm and lay into it like there’s an egg under the gas pedal. Then soft clutch into second, otherwise you’ll tach it on the shift too. Power shift third and fourth is usually ok.
On a sticky - track mode everything, hit the tire hard...get a tire
Old 09-18-2020, 05:46 PM   #4
17MaroSS
Drives: 17 2SS 6sp
So would I lower rear tire pressure?
Old 09-18-2020, 09:17 PM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Here's my approach on my '17 SS manual (100% stock except for Hurst shifter, original 13k mile tires):
  • Lower the rear tire pressure to 26psi once you get to the track (GM's recommendation in performance supplement)
  • Sport Mode (I'm used to the throttle response in Sport)
  • Double click traction control to put system in "Competitive Mode" which turns off TC but leaves some level of stability control in place
  • Drive around water box if possible, back up close to it, and do a short burnout just to get debris off the tires and heat them up slightly. Nothing crazy here for the burnout - just a couple seconds.
  • Pull up to lights slowly and once you trip the 2nd light, stop immediately
  • Rev to 4000 RPM (lower this depending on surface conditions)
  • Release clutch smoothly and relatively quickly while increasing accelerator pedal to manage (minimize) wheel spin. Don't let engine speed bog lower than 3000rpm during this exercise if possible
  • 100% pedal as quickly as possible based on traction
  • No lift shift every gear. I think I start the 1-2 shift around ~6300rpm since that one comes quick, but the others are executed closer to 6450rpm or so.
Using this procedure, my best 60' has been around ~1.9s and best 1/4 mile time is 12.28s at 115.5mph.
Here's a video of that pass (my mic was messed up for some reason!):
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 09-18-2020, 11:13 PM   #6
Fraxum
Fraxum's Avatar
Man respect! You and vtirocz have this down to a science. So much to learn.
Old 09-21-2020, 03:08 PM   #7
asthmamax11
asthmamax11's Avatar
I'm curious if anyone uses the Launch Control feature at the strip.
My tuner got rid of it on my car because it messes with the timing
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-21-2020, 05:44 PM   #8
17MaroSS
Drives: 17 2SS 6sp
Wait 6 speeds have launch control? How do you activate it?
Old 09-21-2020, 06:24 PM   #9
vtirocz
vtirocz's Avatar
I have and it's not very good at the drag strip. On a normal street surface, I've found it can be pretty good, but on a prepped surface I can do a much better job myself.
Yes, they do. Put it in Sport or Track mode. Click the traction control button twice to put the system in "competitive mode." Then, any time your stopped, in first gear with the clutch in, you can put the accelerator pedal to 100% and engine speed will go to ~4500 RPM, let the clutch out and the system will try to manage wheel spin.
Like mentioned above, it hasn't worked well at the track. It either bogs or spins too much and kills the run. I never use it anymore since my method described in the post above is consistently better. Try it out for yourself though - maybe you'll have better luck with it than I did.
With that said, I've found it to be really good (in some cases) on a normal street surface.
Old 11-23-2020, 10:06 AM   #10
SSIXSSPD
Drives: p1x 1le
my best time N/A was 11.9 at track. on the street i used a draggy and the factory launch control and went 12.0. It is definately not consistent though. mostly bogs
SSIXSSPD is offline   Reply With Quote
Old 03-25-2026, 12:51 PM   #11
Lethal6SS
Drives: 2017 Camaro 2SS Fifty
I have been practicing the launch control on my '17 2SS and it's not very good IMO. It revs to about 4600 and when I let the clutch out it wheel spins and seems to bog down for a quick moment. Shouldn't it do a better job of handling wheel spin? Seems like at any RPM higher than 3500 if you release the clutch too quickly the tires will spin. I can probably get better traction with TC and stability on and manually doing the launch myself, but then consistency will be an issue. What is the best way to get the best launch for the best times?
Lethal6SS is offline   Reply With Quote
Old 03-25-2026, 01:05 PM   #12
Lethal6SS
Is there any way to lower the launch control hold RPM to around 3500 instead? Don't see it in the settings or options but maybe a tuner can do it?
Old 03-25-2026, 03:13 PM   #13
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Shift sooner and you will make faster runs. 12.2 is dry public road times
Your peak power is falling after 6000 so to keep powering into that you're intentionally letting your engine lose power while trying to accelerate. If you plan on shifting when you see 5900 you will initiate your shift around 6100. Then put yourself in a rpm position that is increasing in power from the point that you release the clutch again.
If you look at a hp graph you can see the info. At 6300rpm what is your hp and what is your torq?
Vs what was it at 6000rpm?
Old 03-25-2026, 03:34 PM   #14
bishopts
bishopts's Avatar
2017 launch rpm is not adjustable. They didnt start that until 2019. I think they also put in a line lock option too.
