Old 08-08-2020, 08:34 AM   #1
TraderGuy
Drives: Audi TT-RS
Full track width?
Toying with the idea of a ZLE and wondering if it will fit on my four-post lift.
I can get track width from the specs, but I believe that's center of the tire. I'm looking for outside of tire to outside tire width, rears. A C7 Z06/GS fits, just barely. Don't know about the ZLE.
Would appreciate someone taking a measurement and replying.
Thanks!
TraderGuy is offline   Reply With Quote
Old 08-08-2020, 09:24 AM   #2
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
77 Inches give or take a fraction.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 08-08-2020, 10:48 AM   #3
TraderGuy
Drives: Audi TT-RS
Thank you! It would be very tight. The ramps have a 74" width, with three inches of clearance on each side before the wheel hits the pully covers. So a total of 80". Pulling on would need guidance of some sort, a person, mirror, something. Would have to be inch perfect to avoid wheel contact.
Wish I had gone with a wider lift.
Old 08-08-2020, 11:44 AM   #4
Stevezx900
Stevezx900's Avatar
Drives: Buick Grand National, BMW M5
Which lift do you have?
Women Driven on you tube has a ZLE with wider than stock tires on a Bendpak HD7.
I personally went with the HD9 due to the fact that the tracks were adjustable.
My issue is the car is too low to get up on the ramps. I need to try a few 2x4s to help lift the front a little.
Will be trying it tomorrow to do the recommended oil trans and DU change at 1500 miles.
Stevezx900 is offline   Reply With Quote
Old 08-08-2020, 12:27 PM   #5
TraderGuy
Drives: Audi TT-RS
Direct Lift 8Plus. Should have went with the 9. Or better yet a BendPak HD9.
Old 08-08-2020, 01:04 PM   #6
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
Closer to 78”. I had to get a new trailer because it was just too hard to load between the 79” side rails. It would bind up with the slightest turn of the wheel.
m3bs is offline   Reply With Quote
