![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
HUD tach
Is the resolution and responsiveness of the HUD tach good enough to use at the track (primarily drag strip) to determine when to shift, or do you still need to reference the regular tach? I have a non-1LE 1SS and just wondering what I'm missing and if it's good enough to be a substitute for a high mounted tach.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
The HUD has built in shift lights.
The HUD tach, while not as precise as the dash, mirrors the readout. It's the scale on the HUD that is not as large as the dash, and one's a bar, ones a dial.
'18 1SS 1LE Black, PDR
![]() Drives: 2019 1SS 1LE shadow grey Join Date: Jul 2012
When im on the gas going fast , the green ,yellow and red lights on the hud are what im looking at to tell me when to shift
Thanks. Do the ‘17-18 models also have that green, yellow, and red? So red would light up at ~6400 rpm or so? Anyone have a video of it in action. I recall test driving a 2SS back in 2016, but can’t recall that detail (it was an auto too, so might have some differences).
#5 | |
#6 | |
I'm considering selling my SS and buying a used SS 1LE, hence the question.
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Yes. They are on the 1LE.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#8 | |
#9 |
18 SS1LE has the shift lights on the HUD, approaching red line they increase and then flash
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
I turn my HUD way down because I find if I'm looking at it, I miss potholes and other hazards in the road. Not so faint that I can't see it, but enough so it's not the main thing I'm looking at for most driving.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
My 19 SS 1LE has the shift light which is very handy. I shift when it starts flashing. Goes well with the no-lift shift.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#12 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
My 17 1SS 1LE has the shift light functionality included.
#13 |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
There is a slight delay on the HUD speed and rpm readout vs the dash. I only went to the drag strip once so far but for that and track days I have settled on using a target mph number from the HUD speedo readout for each shift: 47mph, 75, 104, 140. From PDR playback review, those targets usually allow me to shift right around 6500rpm or a bit more without hitting fuel cut.
The shift lights come on at the same rpm regardless of the gear so you will be shifting too early into the higher gears if you only reference shift lights. |
#14 |
Not every 1LE has the PDR, though.
Personally I give it a little bit of time after the shift light flashes. It's a very short amount of time(maybe 0.2 seconds) but that usually puts me right at 6500 RPM. I heard the saying that it's better to shift 200 RPM too early than 1 RPM too late. That's just something you have to deal with in a manual. Autos will have more consistent shifts, not to mention faster.
Current:
