Old 08-05-2020, 09:08 AM   #1
HavocZL1
HavocZL1's Avatar
Drives: 2020 Camaro ZL1
Ported TB Question
So I'm trying NOT to void my factory warranty but get a little more power with bolt-ons. Anyone know if a Ported TB will be something that voids the warranty? Thanks.
HavocZL1 is offline   Reply With Quote
Old 08-05-2020, 09:15 AM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
I just got a ported stock one from Soler Performance. I opted to have mine not engraved with any markings, so it looks completely stock from the outside. When it comes to warranty it's just like cold air intake and whatnot. They would need to prove that part caused your problem, but at the same time they could drag things out and make it hell for you. Nice thing is that it's a very comoflagued type mod, and can be swapped out in 10 minutes.
HCI2000SS is offline   Reply With Quote
Old 08-05-2020, 11:12 AM   #3
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
I also have a ported Soler, from the outside it’s a stock GM part @HCI2000SS Is even stealthy then that, but once it’s on not much reason to even pull the air tube and even look a it.
i would swap neighbors before i swapped exhaust
Paintslinger16 is offline   Reply With Quote
Old 08-05-2020, 11:23 AM   #4
az4783054
Drives: SWXXZL1
Keep your stock throttle body if your car needs to go to the dealer. To many people sell their stock throttle body for pennies on the dollar.
I have a Tony Mamo mildly ported throttle body from my previous C7 Z06 with A8. It did make a noticeable no lag 'tip in' difference (to me). I'm at 5,200 ft elevation so I lose some horsepower which the throttle body helped make up.
I've confirmed with Tony that the throttle body will work just fine on my 2020 ZL1 A10 should I decide to install it. Tony says the same throttle body is used on a number of GM trucks and SUVs which is telling.
az4783054 is offline   Reply With Quote
Old 08-05-2020, 11:46 AM   #5
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
As stated, keep your stocker and replace, takes 10 minutes, if you are going to the dealer for a warranty issue. A ported TB is a low risk mod. Does not add much on a dyno but it does, in my case, result in a noticeably sharper part throttle response.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 08-05-2020, 02:12 PM   #6
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I dont think PTB adds power, but my Katech PTB smoothed out the bog/stumble at low throttle.
I found the good dealer in may area and confirmed with the service guys that they wont tell GM about my Rotofab or PTB (if they ever have need to remove pipe and see the Katech logo). If I have a warranty issue I will remove both before bringing in car. I've never had a code for anything.
SFV1LE is offline   Reply With Quote
Old 08-05-2020, 02:56 PM   #7
Hell Raiser
To fast is not enough
Hell Raiser's Avatar
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo
Are the Manual the ones haven bog issue or Auto to. I don't have any bog with mind mash and go. Auto A10
Hell Raiser is offline   Reply With Quote
Old 08-05-2020, 05:49 PM   #8
HavocZL1
HavocZL1's Avatar
Awesome - that's what I was thinking I would do anyway.
Thanks for all the info guys.
Old 08-06-2020, 11:32 AM   #9
ponyboy96
ponyboy96's Avatar
Drives: 2020 ZLE A10, 2018 F250 Diesel
Probably very minimal difference. Spend your cash elsewhere.
ponyboy96 is offline   Reply With Quote
Old 08-06-2020, 03:25 PM   #10
20Bluezl1
I could tell you that the Soler TC makes a difference in throttle feel. Wakes it up doesn't add power but gives it a nice crisp feeling that you can adjust. I also have the Soler TB but I haven't installed it yet.
Old 08-08-2020, 07:33 AM   #11
HavocZL1
HavocZL1's Avatar
Noted! Thanks for the advice.
Old 08-08-2020, 07:51 AM   #12
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Tony Mamo V2 on my SS....it really helps with driving the M6 in town, faster off idle response.
Old 08-10-2020, 03:55 PM   #13
Hell Raiser
Solo Performance claims all the gains. I have not seen them on the site in awhile. Maybe they will chime in on this.
Old 08-10-2020, 04:42 PM   #14
20Bluezl1
All I can say is Soler Performance has great customer service.
