![]() Drives: 2019 Camaro SS Join Date: Jan 2017
Eibach Pro Kit Lowering Springs/ 2019 SS Coupe?
Hey, I could use some advice and thanks in advance!
I was looking at the Eibach Pro Kit lowering springs for my 2019 SS Coupe. Is this a good fit for me? I want to lower the car and have a proper stance while picking up a little cornering ability. Nothing crazy and not tracking the car. Just a fun street car... Also, is it okay to just add the lowering springs or do I need to purchase new struts too? Thanks!
2019 Camaro 1SS. Crush. Mishimoto Catch Can, BMR Strut Tower Brace, Oracle Side Markers, ZL1 Side Skirts, Blade Spoiler W/ZL1 Addons Wicker Bill, Exhaust Cut Outs, BMR Front and Rear Cradle Braces, Cold Air Inductions CAI. ZL1 Rims 285 Fronts and 305's Rear. Speed Inc Tune PCM & TCM.
Long hauler
If you have MRC I don’t see the point other then lowering but that could cause other issues with the ride control sensor.
If not then you’re good to go with just replacing the springs, look up any reviews from a 2016+ SS and it’ll be the exact same as your cars setup Edit: thought I read 2SS, so ignore the MRC stuff then and you’re good to go
2016 1LT v6 - Totaled Happiness: Infinite |
Yeah, no MRC.
Sounds good, just wanted to make sure that I didn't miss anything! I was just concerned that adding just the springs was okay. Thanks!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Even with MRC, the Eibachs work fine. I have had them in my ZL1 for nearly 3 years
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
#6 | |
#7 |
![]() Drives: 2017 SS Coupe 2SS 8AT (427CI, D1X) Join Date: Feb 2018
Expect you will like what the Eibachs do for handling and looks given you have 30 series profile tires.
2017 2SS A8 Coupe w/ Leather/MagRide/Sunroof/Nav Pkg
Mod 1. Rotofab CAI, Borla S, Tony Mamo TB Mod 2 Soler Perf TB, SJM Linelock, Kooks headers, ZL1 sway bars, BMR suspension parts, Eibach springs, MRR 017 LE rims & Michelin PS 4S 285&305/30 tires, GeForce half shafts & alum. driveshaft CSP Build 1/20. Procharger D1X w/Stage 2 IC, Texas Speed 427CI long block w/forged internals/ported LT1 heads/FI cam, LT4 HPFP/injectors, ATI balancer, MM catch can, FTI torque converter, CSP meth injection & aux fuel, Aeroforce gauges, MSD wires, race BOV, PCM/TCM tune. |
#8 | |
Can't wait to get rid of the gap between the tires and body. The streets in the city are garbage so expecting I'll notice the bumps a bit more. While I was planning on the alignment, didn't think of the ZL1 Spec. Thanks for pointing that out! I'll have to research the alignment a bit more.
#9 |
My Eibachs make the car to "appear" lower in the rear than the front. I put Bilstein B6's on it at the same time. A little too harsh for me now. The Bilsteins are softening up just a bit with 1k on them but wish I'd have left the OEM shocks and struts on it.
#10 |
![]() Drives: 2016 Camaro Join Date: Oct 2017
I have the 3/4" Eibach lowering springs and sway bars with Magnetic Ride Control. Zero issues after a year, but sometimes there are clunking sounds in the rear. The rear spring coils are closely wound. The rear coils have a plastic casing (About .100" thick) over the the powder coating. I suspect this is in case of coil bind to prevent metal to metal contact.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
#11 |
![]() Drives: 2023 Sharkskin Metallic 1LE Join Date: Mar 2018
I have the eibach kit on mine, sits good and no issues for the last two years.
#12 | |
It looked low because of the camber being off. Tire tucked up too much. Tire shop could not get it right. Chevy dealer did. Looks right now. Bilstein's off factory set back on.
Straightaways are for fast cars...Turns are for fast drivers
