Old 07-26-2020, 02:54 PM   #1
ReevZL1
ReevZL1's Avatar
Drives: 2019 Chevy Camaro ZL1 A10
ARH combination with another Exhaust System
Does anyone know if the ARH Long Kit (which goes up to the factory Muffler) will fit with the Stainless Works Legend series axel back or Catback Kit?
ReevZL1 is offline   Reply With Quote
Old 07-26-2020, 05:37 PM   #2
ReevZL1
ReevZL1's Avatar
Well I’ll let you know what I find out.
Old 07-27-2020, 07:38 AM   #3
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
Ill be interested as i have the catback. Good luck with the install!
jvandy50 is offline   Reply With Quote
Old 07-27-2020, 07:48 AM   #4
Fredtp
Fredtp's Avatar
Drives: 2019 ZL1 A10 Black Mosaic
I have the ARH system minus the mufflers no cats. If your catback mufflers are 2 3/4" like my Corsa Extreme was they will not fit. I had to to go to muffler guy and have him expand the pipes and weld together. The ARH system is 3".
2019 Black Mosaic ZL1 A10
Kong Ported SC, 2.3 Grip Tec, Roto-Fab Big Gulp, NW103 TB, Mighty Mouse CC, ADM Expansion Tank, ARH 1 7/8 Headers, Catless 3" X-Pipe, Corsa Extreme, Eibach Springs, BMR Cradle Lockout, BMR Trailing/Control arms.
Fredtp is offline   Reply With Quote
Old 07-27-2020, 07:52 AM   #5
Puddin
If he chose the performance connect version then it should just bolt right up because its opened up to 3in already.
Old 07-27-2020, 09:02 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
Usually we have to do some welding. Since there is no true connection point all these systems cut into different locations. Both the headers and the axleback should come with a reducer pipe to meet the factory exhaust. You might be better off ditching those and welding everything else together.
Juiced1 is offline   Reply With Quote
Old 07-27-2020, 06:11 PM   #7
ReevZL1
ReevZL1's Avatar
Thank you for the input everyone.
