Old 07-20-2020, 05:47 PM   #1
Sham001
PushRodLT1
Drives: M1SS1LE
Drops of Oil
I am seeing a few drops of Oil every now and then on my garage floor,
The SS 1LE is almost new, had purchased it at 2250 miles and since have driven only about 400 miles.
Any thoughts on why this might be happening?
Thanks.
2SS Black, M6, NPP, MRC
Mods: Borla ATAK Axleback w/NPP, Roto-Fab CAI, RPI Designs Splitter, ACS Spoiler, Michelin PS4S Tires.
Sham001 is offline   Reply With Quote
Old 07-20-2020, 05:49 PM   #2
caSStro18
Drives: 2018 Camaro SS
Thanks.
Oil changed recently? Could be residual oil that got onto the undercarriage when the filter was removed.
caSStro18 is offline   Reply With Quote
Old 07-20-2020, 05:49 PM   #3
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Check your oil pan bolts, not sure if you have a 19 but my 17 came from the factory with loose oil pan bolts. I forgot the torque on them but there are threads on here about it.
cmitchell17 is offline   Reply With Quote
Old 07-20-2020, 05:50 PM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
i dont think without any info on where you're seeing the oil under your car falling from ...like a picture of the area of the car directly above the pools...nobody is going to be able to tell you anything.
Obviously it's not normal, so ....
Old 07-20-2020, 05:51 PM   #5
Sham001
PushRodLT1
Drives: M1SS1LE
Yes, the dealer had changed oil prior to the sale.
Old 07-20-2020, 07:04 PM   #6
caSStro18
I’d get under there if possible and wipe down the underside. Get as much oil wiped up as you can see. Check that the filter is tight (just turn by hand). Also check the oil drain plug is tight. Recheck in a few days to see if you can spot where the oil is coming from if it continues leaking.
Old 07-20-2020, 07:12 PM   #7
Trochoidal
Drives: 2017 Camaro 2SS A8
I agree with what other said about checking filter and drain plug. However, like cmitchell17 said, check those oil pan bolts. Mine were also loose and I noticed a small drip at second oil change.
https://www.camaro6.com/forums/showthread.php?t=567130
Old 07-21-2020, 06:53 AM   #8
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Mine turned out to be a bad oil pan gasket and was replaced under my powertrain warranty.
dmcmahan60 is offline   Reply With Quote
Old 07-21-2020, 08:47 AM   #9
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I had the exact same issue after the dealer changed the oil in my ZL1. Turned out to be the oil filter.
It was so loose, I had to turn it one complete revolution to get it tight.
Check your filter.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-21-2020, 11:30 AM   #10
Jeb114
Jeb114's Avatar
Drives: 2021 300
Take it back to the dealer and let them check it. so there is a record of it.
Jeb114 is offline   Reply With Quote
Old 07-21-2020, 12:12 PM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
When the filter is loose, oil collects on the underside of the filter. When the drain plug is loose, oil collects on the underside of the drain plug.
It's great to get sight unseen opinions here in the forum, but nothing beats getting under the car as a first step.
Old 07-21-2020, 02:11 PM   #12
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
I had a Wix oil filter develop a pinhole leak......ugh
Old 07-21-2020, 05:31 PM   #13
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I agree with Jeb114! Run it back to the dealer and let them check it out.��
Old 07-22-2020, 07:17 AM   #14
SteveV
SteveV's Avatar
So, it has been 2 days and the OP still hasn't checked under his car?
Man, when I found oil on my driveway, I was under it in a matter of hours...
