Old 07-19-2020, 02:44 PM   #1
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
Lightbulb Check engine light flashing
Hi guys,
Anyone have there check engine light start flashing at them after hard acceleration. My '17 ZL1 did this last night after merging onto the freeway.
The car didn't seem to have any issues accelerating. I got home plugged my scanner into the car. There is a code P0300 Misc Multiple Misfires. Any help would be appreciated.
Thanks, Sam
NW Sam is offline   Reply With Quote
Old 07-19-2020, 04:14 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Misfire my man. Look for a cracked spark plug or bad plug wire. I’m assuming you’re running good gas...
Old 07-19-2020, 06:23 PM   #3
NW Sam
NW Sam's Avatar
Hi Josh,
I buy ethanol free gas from the local co op, along with several other guys in our car group. I haven't heard anybody else complain about the fuel, but I will ask. I will have to pull the plugs and check them.
Thanks
Old 07-19-2020, 06:25 PM   #4
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Flashing CEL is always a misfire, and your code confirms it.
Definitely check it out before it gets worse. You can destroy your cat very quickly otherwise.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 07-19-2020, 10:27 PM   #5
Apexslayer
Drives: Zl1 1le
have you made any modifications?
Apexslayer is offline   Reply With Quote
Old 07-20-2020, 02:35 PM   #6
NW Sam
NW Sam's Avatar
Rotofab CAI
Tony Mamo Throttle body
Both of these mods have been on the car for 3 yrs.
I am pulling the spark plugs and going to replace.
Thanks for all the help, Sam.
Old 07-20-2020, 02:51 PM   #7
NITEMER
NITEMER's Avatar
Drives: 2017 Camaro ZL1
Not saying you have the same issue I do but I had the flashing check engine light and now dealer is saying I need 4 injectors. cylinder 1-3-5-7 not fun
NITEMER is offline   Reply With Quote
Old 07-20-2020, 06:56 PM   #8
NW Sam
NW Sam's Avatar
Do you know what code the dealer retrieved from the computer?
How did your engine run, any hesitation or running rough?
Old 07-21-2020, 09:05 AM   #9
NITEMER
NITEMER's Avatar
I just had rough cold starts not really any hesitation once it was warm, it has the P0300 code.
Old 07-21-2020, 10:56 AM   #10
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Its a bad injector got the same thing going on now rough til warms a bit.. once warm no more codes no more misfire. i did plugs and wires 1st didn't help. seems to be worse if car sits a few days.
you probably will get a stability track light as well.
I'll pull blower soon replace with plus 30's or better and lingenfelter pump..
Old 07-21-2020, 01:58 PM   #11
NITEMER
NITEMER's Avatar
Ye i get the stability track light as well. Im trying to get GM to cover the repair but if they dont I will replace them my self.
Old 05-03-2021, 03:51 PM   #12
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Did you find out what this was? ‘21 SS 1le here only P0300 at track days… I can’t get it to do it on the street
joeyazzata29 is offline   Reply With Quote
Old 05-03-2021, 07:09 PM   #13
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I've had this happen a few different ways
1) Spark plug wire not fully seated
2) Connector at the coil pack with recessed pin
The 2nd one was a bastard, it wouldn't happen on dyno and would only happen on street, likely due to different vibrations.
Old 05-03-2021, 07:51 PM   #14
joeyazzata29
j1ss
Drives: '21 2SS 1LE
It’s just really weird that mine will only do it at a track day. It did it once at the end of a straight around 120mph getting off the gas, and once at like 40mph part throttle.
I would think if mine was either of those issues you described it wouldn’t go back to normal and make it all the way home at 85mph by reconnecting the battery?
