Old 07-19-2020, 10:37 AM   #1
Ants.ZL1
Drives: 2020 ZL1 1LE Shock 1968 Pontiac GTO
2020 ZL1 1LE A10 first 1/4 mile run
We drove the car down to Woodburn raceway in OR yesterday and I made my first run in the car on factory tires. I used the launch control set at 2400 rpm and slip at 8. Not sure I got up on the launch control quite right but I was super happy with the time for my first pass. Second pass I tried with traction control off, thats a no go!! Spun tires at least half track ran a 15 and still hit 121 mph!! We had to leave after that. Came home and ordered some wheels and drag radials!!
Here's the time slip I was in right lane, I haven't been to track in a while so my reaction time is Terrible but I was not really concerned just wanted a good hit.
Ant
Ants.ZL1 is offline   Reply With Quote
Old 07-19-2020, 11:15 AM   #2
Snowwolfe
Drives: CTV5 V Blackwing on order
I would say if that’s your first pass in the Z on street tires you did fantastic!
Well done
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 07-19-2020, 11:28 AM   #3
Markoz28
Drives: 18 ZL1 nightfall grey A10
That’s a solid pass in a ZLE. Going with a drag set up will surely move that beast faster. You may hear a lot that the ZLE is too stiff for drag racing but with the proper wheel and tire selection I’m positive it’ll soften things up.
Keep us posted.
Markoz28 is offline   Reply With Quote
Old 07-19-2020, 12:19 PM   #4
Ants.ZL1
I got a set of mickey 305/45r17 drag radial r for it so well see how it does. I'm not disappointed at all with an 11.50!! And for the record it was absolutely was my first pass at track, I reall haven't even beat on it on steet much either just enough to figure out the line lock and launch control. Car is 100percent stock only thing we did was 5 gal of 109 unleaded to 3/4 tank of 92 oct.
Ant
Old 07-19-2020, 12:40 PM   #5
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
A10 is the drag king, std ZL1 with softer suspension settings is probably a little quicker (better weight transfer)
ZX-10R is offline   Reply With Quote
Old 07-19-2020, 01:27 PM   #6
Ants.ZL1
That makes sense to me, im happy at 11.50 so any improvement is icing on the cake!!
I'll post more slips when I get back to track
Ant
Old 07-19-2020, 02:50 PM   #7
Bow Tie Fanatic
Drives: 2018 Mosaic Black Metallic ZL1 A10
Also it’s probably the worst time of the year to run a decent time as far as DA. I think your time and mph are really good. I’m sure in optimal conditions you’ll drop 2-3 tenths and pick 1-2 mph. Thanks for sharing.
Bow Tie Fanatic is offline   Reply With Quote
Old 07-19-2020, 04:49 PM   #8
Ants.ZL1
Not sure what DA means but if your wondering about air temp it was about 65degrees when I made the first hit
Ant
Old 07-19-2020, 06:54 PM   #9
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Very respectable. Good job! That is not a bad 60 foot time at all for a first time out. Impressed!
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 07-19-2020, 06:55 PM   #10
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
DA is density altitude, it is a calculation of a couple different atmospheric measurements ... lower the DA = better the air = faster the run.
You can expect to run about the same times in similar DA...
Crash76 is offline   Reply With Quote
Old 07-19-2020, 09:16 PM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
reaction time doesn't affect your e.t....the clock starts when your car moves and breaks the starting beam.
Old 07-19-2020, 11:19 PM   #12
ZX-10R
ZX-10R's Avatar
Nice - about 30 degrees cooler than just about everywhere else, that helps
Old 07-20-2020, 07:14 AM   #13
Markoz28
Damn! 65 degrees in July?! I’m in south Texas and it’s 95-100 here during the day. At night it’s about 75 degrees at the lowest with tons of humidity.
Old 07-20-2020, 10:17 AM   #14
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Nice run.
pauly1119 is offline   Reply With Quote
