Old 07-17-2020, 03:13 PM   #1
parish8
Drives: 17 SS a8
Skip 1st gear on tour/sport or track?
With help from this forum I have been able to tune out 1st gear and get auto up shifts while wot in tutd mode. It is great for racing. I would like to program out 1st all the time.
None of the changes I am making to the other tables are getting the car to stay out of 1st gear while in any of the other shift modes. Am I doing something wrong?
Old 11-02-2020, 04:51 PM   #2
Yosh6
Yosh6's Avatar
Drives: 2024 Toyota Camry XSE
Know this is an old post, but would like to see if you got it figured out. I have been working with the three TUTD tables for the purpose of launching in 2nd gear. Getting things pretty dialed in but was burned twice this past weekend by a downshift from M2 to M1 between the burnout and the stage. Didn't notice it, launched in 1st and blew the tires off. The tables had 8 mph in the 2>1 downshift slot. I have changed that to 1. Reluctant to put a zero. Have you tried 0?
2016 1SS - Bought: 8/2017 Sold: 12/2023
Yosh6 is offline   Reply With Quote
Old 11-02-2020, 05:43 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Have you tried setting 2->1 to 318?
Old 11-02-2020, 08:49 PM   #4
Yosh6
Yosh6's Avatar
No. Put a 1 in but haven’t tried it. Your idea sounds better.. Thanks!
Old 11-03-2020, 07:45 AM   #5
KingLT1
KingLT1's Avatar
No problem.
Fwiw 1 just means it will down shift to 1st when it sees 1mph from the speed sensor. 0 means it will down shift to 1st when it sees 0mph. I don't see any condition that would see 318mph, that is usually the "disable" setting for the transmission adjustments. So in theory it should work but I haven't tried it yet.
Old 11-03-2020, 07:53 AM   #6
ItsoverSS
Drives: 2020 1SS Camaro
No problem.
The 🐐 has spoken😉
ItsoverSS is offline   Reply With Quote
Old 11-03-2020, 08:37 PM   #7
Yosh6
Yosh6's Avatar
No problem.
Tried 318 and table would not take that input even though the range indicated was 0 to 318. Put in 0 but have not flashed that tune yet. Based on your logic of a number it will not see should work, then say, 100 should work. Still thinking.
Old 11-19-2020, 04:23 PM   #8
Kerry
Drives: 2019 2SS Camaro
0 will work on a 2019 ss but it will flash on the indactor 1 the 2 then 1 the 2 back and forth but takes off in second. Mine was kinda lazy takeing off in second.
Kerry is offline   Reply With Quote
