Old 07-14-2020, 06:42 PM   #1
Flowtie1
Drives: 2017 ZL1
Headers/Exhaust
This weekend we are installing my ARH LT's and long system exhaust. Has anyone done this same system ? Just wondering about any challenges. Do I really need to wrap my starter to protect it from exhaust heat ? Thanks
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 07-14-2020, 06:58 PM   #2
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
I put the 2 inch system on my 2018ZL1. It wasnt really all that bad! I had it on a lift and the driver side header went in from the bottom, after I un bolted the steering shaft. The passenger side went in from the top, had to move a few things around but it wasnt bad. I havent wrapped my starter but I dont live in South Fla either! Good luck!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 07-14-2020, 07:26 PM   #3
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I put an arh 2 in primaries long system in. Both went in from bottom. I did not take the plugs out or move the coolant reservoir. I did take the intermediate shaft out as well as the bottom aluminum bracing underneath. It was a breeze but it was on a 2 post lift
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 07-15-2020, 05:41 AM   #4
Flowtie1
Drives: 2017 ZL1
Fortunately we have a lift
Old 07-15-2020, 12:57 PM   #5
Agent K
Agent K's Avatar
Drives: 2017 ZL1 6MT
I installed the ARH headers and long system myself on jack stands in my garage...they're 1-7/8". It's been awhile but I think I did mine like 2018ZL1 did his. I had mine ceramic coated. The header install was pretty easy; I didn't have to move a lot of things except the coolant reservoir. Oh, the oil dip stick holder is a bit tricky so take note of how it's routed.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
Agent K is offline   Reply With Quote
Old 07-15-2020, 03:33 PM   #6
2018ZL1
2018ZL1's Avatar
Forgot to add the dipstick dilemma! That was a PITA when I did mine!!!! Mine is in a totally different place than before i installed the headers!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 07-15-2020, 11:20 PM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
It's pretty straight forward. Just make sure before you bolt them up you don't have any clearance issues. If it's close, it might rattle or bang under load or heavy g's. Don't be afraid to dimple a spot or two for a little extra clearance. Another issue is the wiring harness over the passenger header. If you don't zip tie it away from the header it can burn up. These are issues we see with the 2" headers more often then not.
Juiced1 is offline   Reply With Quote
Old 07-16-2020, 06:18 AM   #8
Flowtie1
Drives: 2017 ZL1
thanks to all for your input
