![]() Drives: 2019 SS/1LE Riverside Blue, Z/28s Join Date: Aug 2019
Stock catch can/breather
I have seen a few threads about the nipples on these things breaking off, etc. Is there any reason why you would not consider replacing the stock catch can with one of the aftermarket ones?
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
There isn't a stock catch can.
Very well the PCV air/oil separator, which effectively seems to function like a "catch can"
Is there an air/oil separator? I have not heard that our cars have one. There is just a short tube that goes from the crank case to the intake as far as I know anyway. This is why some people add a catch can.
![]() Drives: 2017 ZL1 Join Date: Apr 2020
There is on LT4
2017 ZL1 M6 Silver Ice Metallic
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
its junk in that regard. it will still let a lot of oil and who knows what else into the air intake. i broke one of the fittings off mine and ordered an aftermarket catch can to replace it. take a look for yourself on your car. remove the tb and check it out. even 100% stock, mine had oil dripping off of it.
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 07-12-2020 at 02:38 PM. |
#9 |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
There is a separate PCV hose running from the block to the intake manifold. The PCV hose is the on “dirty-side” and draws the contaminated fumes (oil, fuel, and moisture) from the engine into the intake manifold. This is where you would install an aftermarket catch can if you want one. |
#11 | |
![]() Drives: 2020 LT1 Join Date: Nov 2019
I don't even want to see what's happening to the car though. |
#12 |
#13 |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Blackheart, if you have warranty left on your Camaro I wouldn’t put a catchcan on the engine as the warranty will be void if you do.
