Old 07-06-2020, 07:57 PM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
IS HITTING REV LIMITER HARMFUL?
I have been out practicing my launches and keeping track of my 60' times and 0-60 times. I hit the rev limiter every time I try to wring every bit of rpm out of my car. I am focused on the HUD tach and it never gets to 6500 before the motor falls away. My first question is, is this harmful to the motor when the rev limiter engages and cuts the power? I have also focused on the MPH and the rev limiter kicks in at 59 mph and strangely (to me) it appears that the car does not achieve 60 mph until l lift off the gas. I thought this car was capable of 63 mph in first gear? Is my technique the problem? Any suggestions on this issue?
MartinLe is offline   Reply With Quote
Old 07-06-2020, 08:16 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the limiter is there to prevent a catastrophic problem but hitting the limiter like that isn't harmful. A mechanical over rev is another problem entirely. I personally have hit the limiter at least 10 times...maybe 20 at VIR. The little hiccup you feel is a fuel cutoff/spark limiter.
Old 07-06-2020, 08:20 PM   #3
MartinLe
MartinLe's Avatar
Thanks.
Old 07-06-2020, 09:51 PM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Hitting the rev limiter is not too bad but don't make a habit of it, it's not a good thing.
I will say that hitting the rev limiter in 1st gear doesn't sound like a good way to drive/shift, you need to shift earlier in 1st especially with this car and the TQ in 2nd. When I hit it on canyons it's always in 2nd. Or 3rd/4th on the track.
SFV1LE is offline   Reply With Quote
Old 07-06-2020, 10:08 PM   #5
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
No.
minn19 is offline   Reply With Quote
Old 07-06-2020, 10:55 PM   #6
Hell Raiser
To fast is not enough
Hell Raiser's Avatar
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo
It is when you hear a big bang then you know it is harmful.
Hell Raiser is offline   Reply With Quote
Old 07-06-2020, 10:57 PM   #7
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I've hit the rev limiter once on my 2020 2SS, it was pretty eye opening... I was in manual mode and was coming down an on ramp and had it to the floor... I was a tad late paddle shifting (using the HUD tach and being "drunk" from the sound of the NPP in "Track Mode" singing a magical tune) and holy crap, it was like someone pulled the rug out on me... My wife gave me the "If you break this damn car doing this crap you aren't getting another one" look... From now on, if I'm really going to romp on it, I'm just gonna stick it in "D" and let the computers do a much better job than I can...
Old 07-07-2020, 04:42 PM   #8
MartinLe
MartinLe's Avatar
I am not waiting for the rev limiter to tell me to shift. My problem was waiting until it too close to redline to shift (yah, yah I've been called worse). Now I am letting off of the gas as soon as the tach hits 6000. I guess the lag between my seeing it hit 6000 and the time I actually let of the gas allows me to hit 60 mph. I've seen it register 61 once.
Old 07-07-2020, 10:35 PM   #9
cdrptrks
cdrptrks's Avatar
The hud output seems to be delayed slightly (both rpms and speed) which is noticeable on 1st gear upshifts and when trying to brake hard to a specific mph. I was ending up about 10mph lower than desired on entry to one corner at a track day due to the HUD lag until I stopped waiting for my desired speed to appear on the HUD before taking my foot off of the brake pedal.
For upshifts you can probably find a lower mph # displayed on the HUD to use as your shift point in order to get the 1-2 shift to happen consistently right around 6500rpm on the physical tach needle without hitting the rev limiter assuming you are always full throttle and not losing traction.
Old 08-13-2020, 12:23 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
My hits the rev limiter at the top of 1st and sometimes 2nd at WOT. It's annoying and probably could be tuned out of the ECU but it's harmless
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-13-2020, 12:58 PM   #11
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Yeah, that's my thought too.
The rev limiter is generally either cutting fuel or cutting spark. Cutting fuel can create a temporary lean spike which is deadly on some highly boosted turbocharge cars, while cutting spark will rain pain on the catalytic converter. Not sure which one the Camaro ZL1 uses. Maybe it cuts both.
So Camaro A10 doesn't automatically upshift in manual mode, then.
I have driven some other cars(mostly family cars) that will upshift for you if you hit the redline in manual mode.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-13-2020, 01:04 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
My comments are based on driving in Auto both in Sport or Track mode
2020 ZL1LE A10.
Old 08-13-2020, 01:04 PM   #13
2SS Capt
2SS Capt's Avatar
Nope, or at least it didn't that time... Feel on its face...
Old 08-13-2020, 05:18 PM   #14
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Have done it a couple times at the drag strip when I forget to put it back in auto after the burnout.
Falls right on its face, noses over, and no harm.
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
