07-06-2020, 04:30 PM | #1 |
Drives: Chevy Camaro SS 1LE Join Date: Jun 2020
Another Tire Post - All Season Tires
Greetings all,
I’ve done a bit of research on A/S tires for my 1LE. I’m considering purchasing two different tire brands for each axle. Rear: Bridgestone Potenza RE 980 A\S (305/30/20) Front: Yokohama Advan Sport A/S (285/30/20) I can’t find any other A/S tires in the above stock sizes. Has anyone run two different brands on different axles? I believe this is doable provided I keep the same tire brand on the same axle. I also believe this is doable for rear wheel drive cars... I want to drive this car in all weather conditions outside of ice/snow; hence, why I’m shopping for A/S tires. TIA/cheers, B
Current: 20 Camaro 1SS 1LE; Crush; Just a few interior/exterior mods; 19 991.2 TT; 19 M240 iX 17 G63; 17 Macan S
Previous Chevys: 89 Z24; 09 C6 Z06; 12 C6 Z06; 12 C6 Base; 13 C6 ZR1 |
07-06-2020, 04:45 PM | #2 |
Ghost Spawn
Drives: Camaro Join Date: Jan 2019
It will be fine running on 2 different brands.
07-06-2020, 05:18 PM | #3 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
I've got the Bridgestone RE980AS Front: 295/30-20 and Rear: 305/30-20 on my 1LE/1SS. No issues, love 'em !!!
07-07-2020, 08:05 AM | #4 |
You don't need the OE sizing, I ran and others have, too, a 275/35 on the Front and a 285/35 on the rear. Speedo wasn't off by even 1mph.
07-07-2020, 09:10 AM | #5 |
Drives: 2018 SS 1LE Join Date: Aug 2018
Yup, you could just go with 295 Bridgestones in the front if you want all 4 tires the same. Did that about 2 years ago and haven't had any issues. Needed A/S tires myself for the Indiana winters.
07-07-2020, 10:00 AM | #6 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
No issues with rubbing up front. |
07-07-2020, 10:42 AM | #7 |
Tks all for ur responses/assurances! Best/B
07-07-2020, 10:46 AM | #8 | |
雪の玉
The measurement specs between oem 285 and 295 are negligible, researched the heck out of it before my purchase. After I got the tires installed, put car on drive on lift and compared my front end before pictures and after and could not see any difference whatsoever to any of the suspension components where rubbing would be an issue. I do notice better driving/handling whenever I get caught driving in the rain. Otherwise it's the same as oem tires. I just don't get too carried away driving in the warm/dry. Also, nice to know that they'll last longer and I can drive year-round. |
07-07-2020, 11:49 AM | #9 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
I would recommend the Continental DWS 06 or Michelin A/S 3+. Not sure if either come in sizes that are close enough
07-07-2020, 12:06 PM | #10 | |
12-03-2020, 06:03 AM | #11 | |
would you be able to post any pics of 295s installed in the front of your 1LE? do these stick out of front fenders / wheel wells any more than 285s ? |
12-03-2020, 08:30 AM | #12 |
雪の玉
Here you go. 1st and 3rd photos are with front stock 285 size goodyears. 2nd and 4th photos are of front 295 all season RE980AS
12-03-2020, 09:03 AM | #13 |
12-04-2020, 01:52 PM | #14 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I went with NITTO Invos on my last couple of camaros. Worked great.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
