Old 07-02-2020, 10:16 AM   #1
NITEMER
NITEMER's Avatar
Drives: 2017 Camaro ZL1
HELP!!! Lots of codes!!!
The car is a 17 Auto ZL1 W/ 29K miles, Only mods are Roto-fab and a TM TB
I keep getting the following codes and seem to only get them after sitting all night, car runs the same as always doesn't even seem like it has a misfire.
P0301 Cylinder 1 misfire
P050D Cold start rough idle
U0401 Invalid data received from ECM/PCM "A"
C0242 PCM indicated PCM malfunction
U042B Invalid data received from chassis control module "A"
P0300 Random/Multiple cylinder misfire
And random diff faults
Started about 2 weeks ago so I took it to the dealer and they said it was because I have the fuse out for the exhaust valves , I paid the diagnostics fee and took my car back. I've had that fuse off since 2017 and no issues till now.
So what i have done since is put a new battery just in case its because of low voltage since it seems to only happen after its been sitting. I swapped Cyl 1 and Cyl 2 ignition coils to see if the issues followed the coil. And I removed Cyl 1 spark plug to look at it. I did this yesterday so I'll wait a couple days to see how this effects anything. Car is out of bumper to bumper but has power-train warranty.
[ATTACH][ATTACH]
[/ATTACH][/ATTACH]
NITEMER is offline   Reply With Quote
Old 07-02-2020, 10:54 AM   #2
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Crusty, I would probably change the plugs
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 07-02-2020, 12:59 PM   #3
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Not a fuse issue, sounds like a bus/wiring issue.
Old 07-02-2020, 02:11 PM   #4
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Take it to another dealer, seams like power-train warranty should cover it. Could be a PC or a harness, maybe even a ground. Have you inspected the wiring for corrosion?
pauly1119 is offline   Reply With Quote
Old 07-02-2020, 02:21 PM   #5
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I have seen other posts on this forum where misfire issues were cleared with new plugs.
It is worth the gamble because new plugs are not that expensive.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-02-2020, 02:26 PM   #6
NITEMER
NITEMER's Avatar
I have not inspected any of the wiring and I will do spark plugs this weekend. I really don't think they are real codes, I do think it is an electrical issue but drive train warranty doesn't cover modules or wiring of any sort, per dealer.
Old 07-02-2020, 03:03 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I got those many codes like that after flashing the PCM. They were "Permanent" codes, though. What are you reading the codes with? A reader, from like Autozone, or something like that?
There have been reports of plug wires wiggling loose. After replacing the plugs, as already suggested, I'd just make sure you get good wire engagement on all the coils and plugs from the wires.
I wonder if you're battery was going bad and the voltage was dropping. Like I mentioned earlier, some of the codes you outlined, would pop-up after a flash. Those would usually go away over time with driving the car. Since you've replaced the battery, I'd just drive the car and see if those codes go away after several cold starts.
'20 ZL1 Black "Fury"
Old 07-02-2020, 04:01 PM   #8
NITEMER
NITEMER's Avatar
I havent flashed the car, I am using one of those cheap Amazon special bluetooth scanners(BlueDriver) The only "Permanent" code is P050D Cold start rough idle
I havent replaced the plugs or coils until yesterday when I removed Cyl 1 plug to inspect it so they shouldnt be loose.
I will drive it around and hopefully it was just the battery being junk.
Old 07-02-2020, 05:10 PM   #9
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I can tell you a low battery has scared me many times with my Corvette. Hopefully that is it.
Old 07-02-2020, 05:22 PM   #10
Get rid of that TB for starters... that is if you have the old one. All kinds of issues pop up with those.
Old 07-02-2020, 05:44 PM   #11
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
If it were me, before I'd change anything I would bring the car back to 100% stock and work from there. Even a loose rotofab clamp will give crazy errors that have nothing to do with the loose clamp, car is misfiring, doesnt mean what you think.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 07-03-2020, 07:49 AM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
My feeling is spark plug replacement, swap to stock throttle body, and recheck all connections to the rotofab including the electrical connection to the MAF. Disconnect battery for 10 min then reconnect. Clear codes and retry.
Old 07-04-2020, 11:45 AM   #13
Rnovrit
Drives: 2018 NFG ZL1-1LE
I got the exact same issue on cyl 8. Change your plugs. If you want to do a little diagnostics, swap the plug/coil/wire to a different cylinder one at a time. Each time clear the codes and test run it. If the misfire follows the component, you found your failed part.
Rnovrit is offline   Reply With Quote
Old 07-04-2020, 03:23 PM   #14
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Is this a crack?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
