Old 06-23-2020, 10:34 PM   #1
Ivar
Drives: 2019 2SS Convertible
2019 2SS Wheel Spacer question
Planning to get wheel spacers, does anyone know exact mm to get it flush on a 2019 2SS with stock rims?
Ivar is offline   Reply With Quote
Old 06-24-2020, 05:55 AM   #2
akelly78
akelly78's Avatar
Drives: 2016 Red 2SS
I believe most people go with a 20 to 25mm spacer for that.
akelly78 is offline   Reply With Quote
Old 06-24-2020, 07:22 AM   #3
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
25mm will poke out. 20mm would be about perfect.
See this thread for pics:
https://www.camaro6.com/forums/showthread.php?t=449883
Here's calculations for the "equivalent spacer" dimension of the 5th gen and 6th gen SS 1LE/ZL1 wheels.
https://www.camaro6.com/forums/showthread.php?t=543018
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 06-24-2020, 03:55 PM   #4
Ivar
From what i've read so far, 20mm front for flush, and 25mm back if you want it to stick out a little. Thanks guys
Old 06-24-2020, 04:36 PM   #5
caSStro18
Drives: 2018 Camaro SS
Do the spacers have any other effect on the car such as steering or suspension issues? Or, do they just change the look slightly by bringing the wheels out a bit?
caSStro18 is offline   Reply With Quote
Old 06-24-2020, 05:05 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Spacers will screw up your alignment and handling and stress wheel bearings.
Similarly window tinting will make it hard to see at night.
Bush league. But hey, it's your car.
Old 06-24-2020, 05:15 PM   #7
caSStro18
That's what I thought...I'll pass!
Old 06-24-2020, 05:47 PM   #8
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
If the right percent of tint is put on the windows there won’t be any problem seeing at night!��
Old 06-24-2020, 06:29 PM   #9
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
5mm spacers with 305/30/20 in rear and 275/35/20 in front is what I have. Looks great and wont screw up anything.
Yellow Beast is offline   Reply With Quote
Old 06-24-2020, 11:34 PM   #10
Ivar
From what I heard obviously as long as you don't go overboard with the spacer you wont feel much difference unless you track/race. Going wider actually will improve handling.
Old 06-25-2020, 09:50 AM   #11
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
+1
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 06-25-2020, 10:16 AM   #12
vtirocz
vtirocz's Avatar
Do you have any evidence a spacer (20mm for instance) would do any of that, or is that an assumption? You could get an alignment checked/set after installing them. I could see some potential benefits from a handling standpoint. How would the stress on wheel bearings be any different than running the SS 1LE/ZL1 wheels with the more aggressive offset?
Old 06-25-2020, 10:29 AM   #13
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Alignment isn't necessarily impacted, but scrub radius is. Basically will make steering feedback to the driver higher since the torque arm acting on the kingpin is now 20mm longer. If you're OK with that then cool, but not necessarily great and can make things like tramlining and steering feel worse since the tire now has more authority over the steering system. Electric power steering would also no longer be optimized.
The center of the contact patch is moved out compared to the larger GM wheels. Those wheels are wider so the center of where force is acting stays about the same whereas just changing offset with a spacer will only move that centroid 20mm further away. A change like that can definitely be the difference between wrecking your wheel bearing or not when hitting potholes or track curbing or other high-impact stuff like that.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-25-2020, 10:33 AM   #14
caSStro18
Doesn't sound worth it to me just to get a slightly different look. Would wider wheels be better instead of spacers? Of course that's the much more expensive option.
